| bkrantz |
Dec 12 2022, 08:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,741 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I recently got a Quickjack 7000 TLX. I need the long X model to reach the jack points on my other vehicles. But I have failed to lift the 914.
My first attempt had the Quickjacks in the "official" positions, i.e. with the lower base pivots forward. Note this is not what I consider safe for 911s and probably for 914s, since the car center of gravity can end up outside (behind) the end of the lower base. Attached thumbnail(s) |
| NARP74 |
Dec 13 2022, 09:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,472 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Well smack me in the head with a salmon. I have been lifting 2 different cars with the "donuts" for years. Now I have to learn a new trick.
| drem914 |
Dec 13 2022, 02:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,078 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California
Well smack me in the head with a salmon. I have been lifting 2 different cars with the "donuts" for years. Now I have to learn a new trick. Where exactly should we be engaging the pinch welds if not the donuts? I thought the donuts were the preferred load points. |
bkrantz 914 on Quickjack 7000TLX--Fail! Dec 12 2022, 08:39 PM
bkrantz But the rear jack point is far forward of the lift... Dec 12 2022, 08:41 PM
bkrantz The front jack point and pad look OK.
But I could... Dec 12 2022, 08:42 PM
bkrantz I then swapped the Quickjacks from side to side, s... Dec 12 2022, 08:43 PM
bkrantz Again, the front lift pad is OK. Dec 12 2022, 08:44 PM
bkrantz And the rear lift pad, as far forward as possible,... Dec 12 2022, 08:45 PM
bkrantz But as the car lifts, and the suspension drops, th... Dec 12 2022, 08:49 PM
76-914 Bob, It has been pointed out to me that those aren... Dec 12 2022, 09:29 PM
Bob, It has been pointed out to me that those are... Dec 12 2022, 09:38 PM
Robarabian You should have the pinch weld rubber pads. You ca... Dec 12 2022, 09:37 PM
Freezin 914 I have the QJ 5000, it is tight by the wheels, but... Dec 12 2022, 10:05 PM
914sgofast2 I have the 5000 model too and it is finicky to get... Dec 12 2022, 10:21 PM
bandjoey Do not try to flip the lift sideways. As it lifts... Dec 12 2022, 10:32 PM
SirAndy You can use the engine crossbar ok.
Only if it is... Dec 12 2022, 10:53 PM
peteinjp
Only if it i... Dec 13 2022, 05:18 AM
mlindner On both front and rear I use a larger board over t... Dec 13 2022, 05:26 AM
Retroracer Seconded (thirded?) for NOT putting any significan... Dec 13 2022, 08:22 AM
Well smack me in the head with a salmon. I have ... Dec 13 2022, 10:45 AM
NARP74
Well smack me in the head with a salmon. I have... Dec 13 2022, 11:00 AM
vitamin914
[quote name='mepstein' post='3045030' date='Dec 1... Dec 13 2022, 02:07 PM
DaveB I use two of the pads interlocked. That allows the... Dec 13 2022, 11:28 AM
PanelBilly I use a 2x6 on each side to make it longer. Dec 13 2022, 01:56 PM
FlacaProductions I'm using an EZCarLift on the donuts without i... Dec 13 2022, 02:24 PM
wonkipop i must admit i use the longs when i have the car o... Dec 13 2022, 03:04 PM
SirAndy ... dunno?
The factory always used all 4 donuts t... Dec 13 2022, 04:13 PM
wonkipop
[quote name='wonkipop' post='3045076' date='Dec 1... Dec 13 2022, 04:37 PM
NARP74 The donuts were younger back then! Dec 13 2022, 03:21 PM
RKramden Cut a slot in a short piece of 4x4 it straddle the... Dec 13 2022, 05:03 PM
Cut a slot in a short piece of 4x4 it straddle th... Dec 13 2022, 07:50 PM
RKramden
Cut a slot in a short piece of 4x4 it straddle t... Dec 14 2022, 11:03 AM
The Double S I have the 7000SLX which I had to use sideways for... Dec 13 2022, 05:59 PM
bkrantz Thanks, everyone.
I agree about the risks of usin... Dec 13 2022, 08:05 PM
PatMc I have a portable mid rise scissor lift, and find ... Dec 14 2022, 06:57 AM
Front yard mechanic I have made up my mind not to buy a quick lift wit... Dec 14 2022, 07:34 AM
Olympic 914
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 07:45 AM
The Double S
I have made up my mind not to buy a quick lift w... Dec 14 2022, 10:18 AM
VaccaRabite
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 07:51 AM
Jim C
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 07:57 AM
PatMc
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 11:37 AM
I have made up my mind not to buy a quick lift w... Dec 14 2022, 11:55 AM
Front yard mechanic
[quote name='PatMc' post='3045242' date='Dec 14 2... Dec 14 2022, 08:21 PM
PatMc
[quote name='PatMc' post='3045242' date='Dec 14 2... Dec 15 2022, 01:29 AM
iankarr
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 09:11 PM
DaveB
I have made up my mind not to buy a quick lift wi... Dec 15 2022, 09:04 AM
dax1969 Have the new 5000 TL wiht increased lift height. ... Dec 14 2022, 08:06 AM
iankarr Amazing work and congrats on entering this next ph... Dec 14 2022, 10:51 AM
burton73 https://garags.com/product/maxjax-m6k-porta...mp;u... Dec 14 2022, 08:56 PM
vitamin914
[url=https://garags.com/product/maxjax-m6k-portab... Dec 15 2022, 06:34 AM
burton73 IS SHIPPING FREE?
Yes, shipping is free in United... Dec 14 2022, 08:59 PM
mepstein I’m sure it’s a scam site. Lots of them around... Dec 15 2022, 07:55 AM
NARP74 Been researching 4 post lifts for storage and work... Dec 15 2022, 09:45 AM
RKramden I beleive these jacks and stackers might require a... Dec 15 2022, 09:50 AM
vitamin914
I beleive these jacks and stackers might require ... Dec 15 2022, 11:29 AM
dhuckabay Have a two post Chinese that I got off eBay. Seem... Dec 15 2022, 09:51 AM
mepstein In my workshop, i have a two post maxjax. I was ab... Dec 15 2022, 01:57 PM
vitamin914 Another way to look for scam websites is to check ... Dec 15 2022, 03:25 PM
peteinjp One other things to keep in find is that we are
of... Dec 16 2022, 06:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th July 2026 - 10:55 PM |
