> 914 on Quickjack 7000TLX--Fail!
bkrantz
post Dec 12 2022, 08:39 PM
I recently got a Quickjack 7000 TLX. I need the long X model to reach the jack points on my other vehicles. But I have failed to lift the 914.
My first attempt had the Quickjacks in the "official" positions, i.e. with the lower base pivots forward. Note this is not what I consider safe for 911s and probably for 914s, since the car center of gravity can end up outside (behind) the end of the lower base.
dhuckabay
post Dec 15 2022, 09:51 AM
Have a two post Chinese that I got off eBay. Seems like it was about $1300 delivered. Is very well built and in five years of daily use have never had a problem. There is a trough that runs two cables and the hydraulic lines between the two posts. Makes getting a low car on a problem. Put down some 2X12's to drive on and takes anything.
bkrantz   914 on Quickjack 7000TLX--Fail!   Dec 12 2022, 08:39 PM
bkrantz   But the rear jack point is far forward of the lift...   Dec 12 2022, 08:41 PM
bkrantz   The front jack point and pad look OK. But I could...   Dec 12 2022, 08:42 PM
bkrantz   I then swapped the Quickjacks from side to side, s...   Dec 12 2022, 08:43 PM
bkrantz   Again, the front lift pad is OK.   Dec 12 2022, 08:44 PM
bkrantz   And the rear lift pad, as far forward as possible,...   Dec 12 2022, 08:45 PM
bkrantz   But as the car lifts, and the suspension drops, th...   Dec 12 2022, 08:49 PM
76-914   Bob, It has been pointed out to me that those aren...   Dec 12 2022, 09:29 PM
mepstein   Bob, It has been pointed out to me that those are...   Dec 12 2022, 09:38 PM
Robarabian   You should have the pinch weld rubber pads. You ca...   Dec 12 2022, 09:37 PM
Freezin 914   I have the QJ 5000, it is tight by the wheels, but...   Dec 12 2022, 10:05 PM
914sgofast2   I have the 5000 model too and it is finicky to get...   Dec 12 2022, 10:21 PM
bandjoey   Do not try to flip the lift sideways. As it lifts...   Dec 12 2022, 10:32 PM
SirAndy   You can use the engine crossbar ok. Only if it is...   Dec 12 2022, 10:53 PM
peteinjp   You can use the engine crossbar ok. Only if it i...   Dec 13 2022, 05:18 AM
mlindner   On both front and rear I use a larger board over t...   Dec 13 2022, 05:26 AM
Retroracer   Seconded (thirded?) for NOT putting any significan...   Dec 13 2022, 08:22 AM
NARP74   Well smack me in the head with a salmon. I have b...   Dec 13 2022, 09:49 AM
mepstein   Well smack me in the head with a salmon. I have ...   Dec 13 2022, 10:45 AM
NARP74   Well smack me in the head with a salmon. I have...   Dec 13 2022, 11:00 AM
vitamin914   [quote name='mepstein' post='3045030' date='Dec 1...   Dec 13 2022, 02:07 PM
drem914   Well smack me in the head with a salmon. I have ...   Dec 13 2022, 02:18 PM
DaveB   I use two of the pads interlocked. That allows the...   Dec 13 2022, 11:28 AM
PanelBilly   I use a 2x6 on each side to make it longer.   Dec 13 2022, 01:56 PM
FlacaProductions   I'm using an EZCarLift on the donuts without i...   Dec 13 2022, 02:24 PM
wonkipop   i must admit i use the longs when i have the car o...   Dec 13 2022, 03:04 PM
SirAndy   ... dunno? The factory always used all 4 donuts t...   Dec 13 2022, 04:13 PM
wonkipop   [quote name='wonkipop' post='3045076' date='Dec 1...   Dec 13 2022, 04:37 PM
NARP74   The donuts were younger back then!   Dec 13 2022, 03:21 PM
RKramden   Cut a slot in a short piece of 4x4 it straddle the...   Dec 13 2022, 05:03 PM
mepstein   Cut a slot in a short piece of 4x4 it straddle th...   Dec 13 2022, 07:50 PM
RKramden   Cut a slot in a short piece of 4x4 it straddle t...   Dec 14 2022, 11:03 AM
The Double S   I have the 7000SLX which I had to use sideways for...   Dec 13 2022, 05:59 PM
bkrantz   Thanks, everyone. I agree about the risks of usin...   Dec 13 2022, 08:05 PM
PatMc   I have a portable mid rise scissor lift, and find ...   Dec 14 2022, 06:57 AM
Front yard mechanic   I have made up my mind not to buy a quick lift wit...   Dec 14 2022, 07:34 AM
Olympic 914   I have made up my mind not to buy a quick lift wi...   Dec 14 2022, 07:45 AM
The Double S   I have made up my mind not to buy a quick lift w...   Dec 14 2022, 10:18 AM
VaccaRabite   I have made up my mind not to buy a quick lift wi...   Dec 14 2022, 07:51 AM
Jim C   I have made up my mind not to buy a quick lift wi...   Dec 14 2022, 07:57 AM
PatMc   I have made up my mind not to buy a quick lift wi...   Dec 14 2022, 11:37 AM
mepstein   I have made up my mind not to buy a quick lift w...   Dec 14 2022, 11:55 AM
Front yard mechanic   [quote name='PatMc' post='3045242' date='Dec 14 2...   Dec 14 2022, 08:21 PM
PatMc   [quote name='PatMc' post='3045242' date='Dec 14 2...   Dec 15 2022, 01:29 AM
iankarr   I have made up my mind not to buy a quick lift wi...   Dec 14 2022, 09:11 PM
DaveB   I have made up my mind not to buy a quick lift wi...   Dec 15 2022, 09:04 AM
dax1969   Have the new 5000 TL wiht increased lift height. ...   Dec 14 2022, 08:06 AM
iankarr   Amazing work and congrats on entering this next ph...   Dec 14 2022, 10:51 AM
burton73   https://garags.com/product/maxjax-m6k-porta...mp;u...   Dec 14 2022, 08:56 PM
vitamin914   [url=https://garags.com/product/maxjax-m6k-portab...   Dec 15 2022, 06:34 AM
burton73   IS SHIPPING FREE? Yes, shipping is free in United...   Dec 14 2022, 08:59 PM
mepstein   I’m sure it’s a scam site. Lots of them around...   Dec 15 2022, 07:55 AM
NARP74   Been researching 4 post lifts for storage and work...   Dec 15 2022, 09:45 AM
RKramden   I beleive these jacks and stackers might require a...   Dec 15 2022, 09:50 AM
vitamin914   I beleive these jacks and stackers might require ...   Dec 15 2022, 11:29 AM
dhuckabay   Have a two post Chinese that I got off eBay. Seem...   Dec 15 2022, 09:51 AM
mepstein   In my workshop, i have a two post maxjax. I was ab...   Dec 15 2022, 01:57 PM
vitamin914   Another way to look for scam websites is to check ...   Dec 15 2022, 03:25 PM
peteinjp   One other things to keep in find is that we are of...   Dec 16 2022, 06:10 AM
- Lo-Fi Version Time is now: 25th July 2026 - 10:52 PM
