| cal914 |
Mar 3 2017, 02:52 PM
Member ![]() ![]() Group: Members Posts: 321 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
Im looking to fit a Momo steering to my 1971 914 but i can't find anywhere that sells the right Hub,they either sell Hubs for 914-6 or for a 72-76 car
Any ideas where i might buy one Thanks Brian |
| GregAmy |
Jan 27 2023, 09:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
That may be a JDM Momo steering wheel, some Japanese cars had that, but with a center cover that fit between those padded areas where the thumb lies. Also used in Europe. I snagged one of those off eBay for the race car (mine is 380mm).
You'll need a closer photo for that sig. Install one of the below. It will move the steering wheel up to get the wheel out of the way of viewing the gauges, and will space the wheel toward you a little bit. You won't even notice the eccentric when you're using it. https://www.jwestengineering.com/Steering-E...apter_p_19.html |
| scott_in_nh |
Jan 27 2023, 10:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 811 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
That may be a JDM Momo steering wheel, some Japanese cars had that, but with a center cover that fit between those padded areas where the thumb lies. Also used in Europe. I snagged one of those off eBay for the race car (mine is 380mm). You'll need a closer photo for that sig. Install one of the below. It will move the steering wheel up to get the wheel out of the way of viewing the gauges, and will space the wheel toward you a little bit. You won't even notice the eccentric when you're using it. https://www.jwestengineering.com/Steering-E...apter_p_19.html I'm considering the offset and will likely go that way if I stay with the Proto. For now at least I will install the longer hub. Here is the signature Attached image(s)
| gokart73 |
Jan 27 2023, 03:08 PM
Newbie ![]() Group: Members Posts: 16 Joined: 11-July 19 From: USA Member No.: 23,293 Region Association: None |
That’s a Niki Lauda Momo from the late ‘70’s or early ‘80’s. Should be a X - XX month/date stamped on the back.
Not a lot of survivors. Certainly worth restoring or refurbishing. |
cal914 Fitting Momo steering wheel Mar 3 2017, 02:52 PM
GeorgeRud I believe the hub may have been discontinued so yo... Mar 3 2017, 03:01 PM
stevend914
Im looking to fit a Momo steering to my 1971 914 ... Mar 3 2017, 04:36 PM
brubou
Im looking to fit a Momo steering to my 1971 914 ... Mar 3 2017, 06:09 PM
Rleog The Momo adapter for 70-early 71 914s is no longer... Mar 3 2017, 06:37 PM
ndfrigi When I still have the 71 1.7 megasquirt, i planned... Mar 3 2017, 07:16 PM
Blue6 Agree with Noel, the momo part number you need is ... Mar 3 2017, 07:35 PM
porschetub Yes exactly,found 2 early ones on ebay,late are 80... Mar 3 2017, 08:53 PM
plays with cars Bummer, thought that I had one for you. But I che... Mar 3 2017, 09:01 PM
7TPorsh I had the same problem finding one. Finally found ... Mar 3 2017, 09:22 PM
turnaround89
This is what I have started doing on my current ... Mar 4 2017, 03:43 PM
Tjmrfe
Im looking to fit a Momo steering to my 1971 914 ... Mar 4 2017, 04:01 PM
Tjmrfe
Im looking to fit a Momo steering to my 1971 914... Mar 4 2017, 04:05 PM
GregAmy Has anyone tried installing a later upper column t... Mar 4 2017, 04:23 PM
BeatNavy
Has anyone tried installing a later upper column ... Mar 4 2017, 05:57 PM
GregAmy
Yes and no:
http://www.914world.com/bbs2/index.p... Mar 5 2017, 07:26 PM
BuddyV What is the Momo hub model # for later cars... .sa... Mar 6 2017, 09:11 PM
GregAmy
What is the Momo hub model # for later cars... .s... Mar 6 2017, 09:45 PM
JoeD
What is the Momo hub model # for later cars... .s... Mar 7 2017, 09:37 AM
sithot I'm on my second 8002 and it's not going o... Nov 1 2021, 02:59 PM
vin man For my 1971 914-4, I ordered one of these from Cla... Mar 7 2017, 09:10 AM
GreatPumpkin So I’ve been looking for answers on this for som... Nov 2 2022, 03:47 PM
sithot
At the end of the day, all three will fit just ... Nov 2 2022, 07:54 PM
Varooom Here is my newly added Momo 370mm. Size is factory... Nov 2 2022, 04:35 PM
GreatPumpkin
Here is my newly added Momo 370mm. Size is factor... Nov 2 2022, 04:46 PM
Varooom
Here is my newly added Momo 370mm. Size is facto... Nov 3 2022, 11:02 AM
Cairo94507 Very nicely done- that looks great. :beer2: Nov 2 2022, 05:05 PM
r_towle Can’t recall, but I made a ring that bolted on t... Nov 2 2022, 06:04 PM
dr914@autoatlanta.com Jeff at Classico steering wheels sells an adaptor ... Nov 3 2022, 02:46 PM
Retroracer
Im looking to fit a Momo steering to my 1971 914 ... Nov 3 2022, 04:30 PM
sithot Apparently the Solid Hub 8002 is all there is for ... Nov 9 2022, 06:53 AM
scott_in_nh About 10 years ago my son bought and installed a P... Jan 27 2023, 09:26 AM
scott_in_nh
That’s a Niki Lauda Momo from the late ‘70’... Jan 27 2023, 03:47 PM
Freezin 914
That’s a Niki Lauda Momo from the late ‘70â€... Jan 27 2023, 08:57 PM
scott_in_nh I did install the longer of the two 8002's wit... Jan 27 2023, 04:23 PM
SKL1 Glad I got the MOMO Jackie Stewart wheel and adapt... Jan 27 2023, 10:23 PM
CCE Got my momo from Amazon, with a Porsche hub, did n... Jan 28 2023, 02:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:47 AM |
