| r_towle |
Feb 8 2023, 06:31 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Hi,
I have a 997 (this feels like the start of a support group thing) This car has an electric front hood latch. So, the battery needs to be hooked up to open the front hood where the battery is... Its not logical, but Porsche put in a shortcut. So, go to the fuse box inside, pull out a red lead, and hook up a 12VDC battery to this lead, and chassis ground... Hood opens. Instead of using a full size heavy car battery, I went and bought a lithium battery "jump box" thing Schumacher SL1639 Lithium Portable Power Pack and 1000A 12V Jump Starter So, it will not work. We ended up getting a full size battery, with jumpers, just to open the hood, so we could reconnect the battery. My question is...WHY does it not work? When I put my meter on it, I see 16VDC ITs fully charged. Its on. The Tech support told me the unit can only be used for jump starting a car. The mechanic at the shop told me he also had this issue, and the unit needs to see a load?? I will return this if it will never work...but I really need to know why it won't work. I can get a motorcycle battery, or some other unit that will take care of my needs...but this thing should work...yet it does not. Anyone care to explain electricity to me? Rich |
| theer |
Feb 9 2023, 12:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
Rich- I had the same thing happen to a friend’s 911 (I only run with the crowd owns these fancy-pants cars, don’t have one myself.). Anyway, I used a regular jump pack - the big heavy one- and it worked fine.
I have also used the same jump pack to run the 12v winch on my car trailer. Works fine for that, too. Maybe the little lithium ones have some kind of security/safety BS thing to protect it…? |
| Superhawk996 |
Feb 9 2023, 08:03 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,886 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Maybe the little lithium ones have some kind of security/safety BS thing to protect it…? The thing everyone loses sight of is that Lithium-ion batteries are not “just” a battery. Lithium ion batteries are volatile. As such, almost everything except a raw cell has a battery management system to protect them from being fully drained below 10-20% of capacity. Likewise they are protected from over charging. They are protected from short circuits. Lithium-ion batteries can self oxidize (I.e burn) due to thermal runaway if the cell gets too hot from being charged or discharged to fast. This is all done by a microprocessor (and other electronics) controlling the battery. Even single cells can have a very simple battery management system on them. If the battery management system wants to limit current in or out it can do so. In your case, current is being limited until it sees a load that looks like a battery (connected proper polarity) and a low resistance load like a starter motor. Not just a battery. ![]() https://lygte-info.dk/info/battery%20protection%20UK.html Note: mechanical engineer but don’t hold it against me - I play with electrons too! |
| jd74914 |
Feb 9 2023, 01:23 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,880 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Maybe the little lithium ones have some kind of security/safety BS thing to protect it…? The thing everyone loses sight of is that Lithium-ion batteries are not “just” a battery. Lithium ion batteries are volatile. As such, almost everything except a raw cell has a battery management system to protect them... (IMG:style_emoticons/default/agree.gif) Those protections are there for good reason. Some jump boxes (looking at you Noco Genius) have override buttons so you can start a battery-less car with them. The button is a tacit user acknowledgement that the situation is appropriate for the given use. In any case, they work pretty good for things like starting diesel tractors missing a battery, etc. |
r_towle need an Electrical engineer to explain this Feb 8 2023, 06:31 PM
mgphoto 2 words Ohms Law. Feb 8 2023, 07:09 PM
worn
2 words Ohms Law.
I raise you with ROYGBIV. I g... Feb 8 2023, 07:22 PM
r_towle Sorry….I read ohms law and I don’t get why thi... Feb 8 2023, 07:36 PM
914GT Do you see 16v with it attached to the load? I su... Feb 8 2023, 07:38 PM
r_towle
Do you see 16v with it attached to the load? I s... Feb 8 2023, 07:48 PM
76-914 Rich, buy a 12v cordless drill battery or 8 flashl... Feb 8 2023, 07:43 PM
r_towle
Rich, buy a 12v cordless drill battery or 8 flash... Feb 8 2023, 07:47 PM
mepstein The jump packs are really great in the usual situa... Feb 8 2023, 08:04 PM
StarBear
The jump packs are really great in the usual situ... Feb 9 2023, 07:35 AM
r_towle I have larger jump packs..
I wanted something lig... Feb 8 2023, 08:37 PM
bkrantz Not sure about 997s, but my 991 has a hidden pull ... Feb 8 2023, 09:00 PM
r_towle Yes we found and tested that pull.
Can you imagine... Feb 8 2023, 10:38 PM
bzettner
Can you imagin... Feb 9 2023, 08:15 AM
87m491
Can you imagin... Feb 9 2023, 02:09 PM
Geezer914 12V alarm battery or 12V lawnmower battery. Feb 9 2023, 07:00 AM
Front yard mechanic My cheap hf battery charger has a chip in it it ha... Feb 9 2023, 07:44 AM
GregAmy
My cheap hf battery charger has a chip in it it h... Feb 9 2023, 07:48 AM
fixer34 I've been around electricity and electronics e... Feb 9 2023, 07:26 PM
r_towle Yah…I may go order a Milwaukee power access thin... Feb 9 2023, 07:34 PM
targa72e I will just echo what others have said. The device... Feb 10 2023, 12:21 AM
GregAmy Of course, why in the hell Porsche put the battery... Feb 10 2023, 07:48 AM
mepstein These will fit in the palm of your hand and start ... Feb 10 2023, 07:59 AM
fixer34
These will fit in the palm of your hand and start... Feb 10 2023, 05:03 PM
Superhawk996
These will fit in the palm of your hand and star... Feb 10 2023, 05:22 PM
r_towle Funny timing
I left the trailer hooked up which ki... Feb 10 2023, 05:51 PM
Superhawk996
Funny timing
I left the trailer hooked up which k... Feb 11 2023, 08:51 AM
r_towle It’s cute, but I’m returning it because it doe... Feb 11 2023, 03:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th June 2026 - 07:56 AM |
