BAT 76 914, Cleanup and Interior redo |
bradburm |
Feb 16 2023, 06:54 PM
Newbie Group: Members Posts: 16 Joined: 8-May 22 From: Houston/Austin Member No.: 26,531 Region Association: Southwest Region |
I bought a 76 on Mothers day that needed quite a bit of TLC - so this being my first go at clean up and redo of anything Porsche after much help with questions on here, i am just about finished. I do all my own work and my shop isn't close by so it takes time and patience.
Here is what I have taken care of, I am sure some of you purist will not like some of the changes I have made but functionality was key to me. I have completely redone the interior, switched from all extremely dirty white, carpet and seats, door panels, backing and arm rest to a charcoal carpet, black arm rest and white seats, backing, door panels. Took care of all the surface rust in the back trunk. Went through the engine everything checked out fine. I also surveyed the rest of the frame for any rust, etc which i cleaned up. I am awaiting delivery of the parking brake sensor to install the drivers seat and then need to spend some time cleaning the engine compartment up a bit I will post pictures So thinking about my next project, 944 or 928 maybe, the pricing seems to be right Thank you for everyones help |
rjames |
Feb 17 2023, 11:02 AM
I'm made of metal Group: Members Posts: 3,948 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Looks like you painted over the tar on the floorboards? Better to have pulled that stuff up first to make sure there wasn't rust hiding under it (usually is) or just have left it as it was for the next owner.
Love the car's color combo! |
Jett |
Feb 18 2023, 12:46 PM
Senior Member Group: Members Posts: 1,640 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Looks like you painted over the tar on the floorboards? Better to have pulled that stuff up first to make sure there wasn't rust hiding under it (usually is) or just have left it as it was for the next owner. Love the car's color combo! +1 for this car I would spend a weekend pulling up the tar on the floors and then repairing the rust against the firewall and then put back the sound deadening. (IMG:style_emoticons/default/smile.gif) We have a 75 that looked totally rust free but sure enough there was rust there, and I suspect it is from car washing. |
bradburm |
Feb 18 2023, 05:37 PM
Looks like you painted over the tar on the floorboards? Better to have pulled that stuff up first to make sure there wasn't rust hiding under it (usually is) or just have left it as it was for the next owner. Love the car's color combo! +1 for this car I would spend a weekend pulling up the tar on the floors and then repairing the rust against the firewall and then put back the sound deadening. (IMG:style_emoticons/default/smile.gif) We have a 75 that looked totally rust free but sure enough there was rust there, and I suspect it is from car washing. I hear you guys - if you noticed i scraped some of the tar back and no signs of rust showed - I also chose to do a tap test (I do this on my Mopars) in 1 inch spans to see if the instrument goes through the floorboard, panel etc - I did the same across the floorboards and firewalls, there were no punctures or significant gaps/holes - so I saved myself time and sealed it. No paint, Eastwood Rust Encapsulator - to prevent any future rust hopefully. |
rjames |
Feb 24 2023, 09:58 PM
Looks like you painted over the tar on the floorboards? Better to have pulled that stuff up first to make sure there wasn't rust hiding under it (usually is) or just have left it as it was for the next owner. Love the car's color combo! +1 for this car I would spend a weekend pulling up the tar on the floors and then repairing the rust against the firewall and then put back the sound deadening. (IMG:style_emoticons/default/smile.gif) We have a 75 that looked totally rust free but sure enough there was rust there, and I suspect it is from car washing. I hear you guys - if you noticed i scraped some of the tar back and no signs of rust showed - I also chose to do a tap test (I do this on my Mopars) in 1 inch spans to see if the instrument goes through the floorboard, panel etc - I did the same across the floorboards and firewalls, there were no punctures or significant gaps/holes - so I saved myself time and sealed it. No paint, Eastwood Rust Encapsulator - to prevent any future rust hopefully. You saved yourself time but made more work for the next owner to do it right. When I removed the tar on my car there was rust underneath in many spots even though there were no signs on the surface. The rust can come from the underside of the car, too. Not trying to be an ass, just like seeing things done right the first time around. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:05 AM |
