| Mueller |
Dec 16 2004, 10:04 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
for my 2316 it seems that the stock plenum might be reaching it's limits as far as volume goes.....so, I either fabricate a larger common plenum, or go with individual throttle bodies such as TWM or Jenvey*
single plenum would be easiest, but the individual throttle bodies look better (IMG:style_emoticons/default/smile.gif) has anyone switched from one to the other on the same motor with everything else being the same??? *Jake Raby is the U.S. distributor of these.... |
| Bleyseng |
Jan 20 2005, 07:35 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Well, you are mixing apples and oranges since carb vents and TB's have little in common. The venturi is where the fuel is mixed and you must achieve proper atomization. The TB is a air metering device sized by the air charge needs.
Dual TB's suffer from poor driveablity and tuning but a great for drag racing where they are tuned for one basic rpm (WOT). The plenum and runners FI is a different concept than dual carbs. Since the intake air doesnt have to hold fuel in it and the fuel is delivered smack on the valve, its more tuneable. The runners are sized to hold atleast one chambers volume for an intake stroke. The plenum holds the recharge air plus additional as there is overlap from other cylinders. How the engineers calculate this with math is beyond me. I am hoping out resident math wiz has figured it out! Geoff |
Mueller Common plenum or individual runners??? Dec 16 2004, 10:04 PM
lapuwali Biggest problem with IR throttles is getting a goo... Dec 16 2004, 10:18 PM
ottox914 Here is another place to check for FI throttle bod... Dec 16 2004, 10:18 PM
Bleyseng <... Dec 16 2004, 10:41 PM
rdauenhauer Im not smart enough to follow this ... :wacko:
Wh... Dec 16 2004, 10:56 PM
Bleyseng air velocity I think. Under lite vacuum at cruisin... Dec 16 2004, 11:01 PM
Cloudbuster The general gist is short intake runners for high ... Dec 16 2004, 11:10 PM
Mueller Geoff,
Based on another thread in which Jake ment... Dec 16 2004, 11:55 PM
Bleyseng The difference between a 2270 and a 2316 isn't... Dec 17 2004, 12:17 AM
ottox914 My very basic understanding of plenum and runners ... Dec 17 2004, 08:25 AM
Jake Raby Bleyseng,
I have never had ANY engine that I could... Dec 17 2004, 08:54 AM
Bleyseng Jake, I am going with the Megasquirt setup but ret... Dec 17 2004, 09:02 AM
Jake Raby I'm sure he can make it run right, but the que... Dec 17 2004, 09:11 AM
Bleyseng Ok, 'bout how much more Volume do you think it... Dec 17 2004, 09:15 AM
Jake Raby :lol2: Dec 17 2004, 09:41 AM
Mueller
jwalters ... Dec 17 2004, 05:57 PM
Jeroen Mike, do a search on the pelican taildraggers foru... Dec 17 2004, 10:16 PM
Mueller
Qarl http://www.abdgraphics.com/iansite/ianthro...rottl... Dec 17 2004, 11:40 PM
SirAndy <... Dec 18 2004, 02:33 AM
Brett W The common plenum system will make more power than... Dec 18 2004, 08:07 AM
Mueller <... Dec 18 2004, 01:31 PM
Aaron Cox heres a wild thought....use carb manifolds.... wel... Dec 18 2004, 01:42 PM
TimT Mike the GT3RS we just tore down has a big box ple... Dec 18 2004, 02:09 PM
Mueller
Aaron Cox beautiful drawings :trophy:
pony up for the jen... Dec 18 2004, 02:24 PM
Bleyseng Aaron, I was thinking along those lines last night... Dec 18 2004, 03:25 PM
Aaron Cox ... Dec 18 2004, 03:26 PM
SirAndy ... Dec 18 2004, 04:32 PM
Mueller the 3.2 upper might work, my issue with it is that... Dec 18 2004, 05:09 PM
SirAndy <... Dec 18 2004, 05:25 PM
Aaron Cox <... Dec 18 2004, 05:34 PM
Mueller
RD Evans Here is a link to a custom made manifold that migh... Dec 18 2004, 06:32 PM
Mueller thanks for the link...nice and simple manifold....... Dec 18 2004, 06:39 PM
Bleyseng Hmm, I thought the intake valves on a 3.2l are 49m... Dec 18 2004, 06:49 PM
TimT This guy makes a nifty throttle alternative "barr... Dec 18 2004, 06:54 PM
Mueller pretty damn slick Tim........much easier to seal t... Dec 18 2004, 07:28 PM
DNHunt I can't offer much except that about the only ... Dec 18 2004, 07:50 PM
Air_Cooled_Nut <... Dec 18 2004, 08:29 PM
Jeroen IIRC slide valves only work better at WOT, when th... Dec 18 2004, 08:47 PM
SirAndy ... Dec 18 2004, 09:45 PM
Bleyseng hmmm, that is damn close then. Someone here must k... Dec 18 2004, 11:04 PM
Bleyseng Andy, what size is the 3.2l TB?
65mm TB Dave, damn... Dec 18 2004, 11:16 PM
Brett W The early 90s Honda Prelude which was a 2.0 engine... Dec 19 2004, 12:38 AM
SirAndy ... Dec 19 2004, 12:45 AM
914efi This is what I built for my 2.2E engine. It seems ... Dec 19 2004, 08:37 AM
Mueller 914efi, nice DIY job :trophy:
a couple of quest... Dec 19 2004, 12:21 PM
Brett W Mike,
The slide throttles could work fine on a str... Dec 19 2004, 01:55 PM
Jake Raby I have tested Kit Carlson with I/R on a 2563cc eng... Dec 19 2004, 02:08 PM
Air_Cooled_Nut http://www.91... Dec 20 2004, 08:05 AM
914efi I bought a 3.2 intake on the advice of a local ... Dec 20 2004, 08:55 AM
914efi another view Dec 20 2004, 12:45 PM
Bleyseng Take a look Mueller. Dec 20 2004, 03:30 PM
jwalters Dec 20 2004, 03:54 PM
TimT Mike here is the GT3RS plenum, I couldnt find wher... Dec 20 2004, 04:19 PM
TimT nuther Dec 20 2004, 04:20 PM
TimT YOu bolt the different restrictors to that round ... Dec 20 2004, 04:22 PM
Mueller thanks Tim,
that is a huge plenum...and dusty to... Dec 20 2004, 04:48 PM
TimT
