Clutch pedal travel excessive |
peteinjp |
Apr 10 2023, 06:53 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not wanting to put any undue pressure on the TOB I pulled the cable end as far forward as i could while pushing the clutch lever as far back and adjusted the cable with no free play. Tube is good, cable, pressure plate, flywheel etc all have about 30,000kms. Pedal stop is low and yet I have to push the pedal all the way to the floor to keep from grinding in 1st and reverse. I can not pull the pedal back at all as described in the factory manual. It works but barely- the travel is too far even with the cable adjusted with slight pressure on the shift fork lever.
It seems to me there should always be just the slightest play in the cable- no?? Any thoughts? Pete |
peteinjp |
May 7 2023, 09:53 PM
I thought a bit about the light weight flywheel after posting- the unit in the car is a Qsc and supposedly 13lbs. Didn’t seem heavy… Pete I noticed the AA Performance has one listed @ $235 and it is drilled like the 914/6 original,I have purchased 2 flywheels from them and found them to be good quality. Cheers. Thanks for that. At this point question the quality of the cheap QSC unit that was used in the car. Probably fine and I'll throw it back on and check the runout... Based on this thread I think I'll stick with something German made. Seems mat AA has some questionable parts..... Sachs/flywheel fit Mostly what I need to know is if the stock 215mm PP are up to the task and if not what PP should be used. My gut says yes but would be nice to know for sure. Pete |
Lo-Fi Version | Time is now: 7th June 2024 - 08:38 PM |
