| jhynesrockmtn |
Jun 21 2023, 07:30 PM
Member ![]() ![]() Group: Members Posts: 447 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest
Hi, working away on a refresh of some items on my Bumblebee. One of the items I want to address is the cheap carpet kit it has that has not been installed very well to boot.
I am going to place an order for a kit. The question is which color. I want to go with the German Loop. There is a black, early charcoal and late charcoal. Which color is the most appropriate for a Bumblebee with a black interior. ![]() |
| wonkipop |
Jul 1 2023, 09:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
@Mikey914
you have to be cautious these days matching carpet to original samples. its all 50 year old material you are dealing with in original cars. it seems not only was the brown carpet notorious for fading, it looks like the later type of black carpet also fades significantly. here is some shots of that very original 06/74 1.8 i had on file. with carpet lifted to show areas that have not been subject to UV exposure and wear. its actually pretty dark in terms of both the thread colors. (mind you, i will bet the black stayed stable for a lot longer than the brown. the brown carpet resistance to UV could be measured in days instead of years. (IMG:style_emoticons/default/biggrin.gif) ) in the last image you can see just how much fade there is in the original carpet exposed to UV. also. mr. b will be dead right with his tracking of the precise week it switches over to the later carpet. its got nothing to do with limited edition production. its there in the 1.8s as well - just we never got the date narrowed down as close as he has. but our 1.8 data confirms his. ------ and why do they change the carpet? this tells you why. they start up the production line in 04/74 for the scirocco at karmann. or at least that is the date most sources give for when the scirocco commences. i have read other sources which indicate early pre production cars came down the line in oct 73 and they were gradually running batches of cars sorting out the line from oct 73 to march 74 before scaling up to full production but only for domestic and european supply. the lines were further expanded in 1975 as production commenced for the USA market with the 76MY. at that point the 914 was restricted to a corner of the factory and a dribble of production. here is the color/interior palette for the 74 scirocco. its the german brochure and its dated 01/74 for printing. you will recognize everything in it pretty much. bit by bit the 914s received these fabrics and changes in material beginning with 75 MY 914s in earnest. but a bit also dribbles in at random points along the way with 74 914s. (as we have been finding out even the AFM unit for a 6 pin 74 injection loom gets revised quite a bit internally for later bosch spare part replacements). as a side note the scirocco, golf and passat (rabbit and dasher in the USA) also had plastic fuel tanks. world first in a car. in may 74 the 914 received the plastic expansion tank on its fuel tank as part of this innovative product development. its all connected to the water cooled car R&D updated materials. there is other stuff along the way dotted throughout the 74MY that makes me think the 914 was benefiting from approaches to materials and components being developed for the new water cooled models. all of which no doubt were aimed at better outcomes in terms of manufacturing cost amongst other engineering considerations. i've never found a good picture of a 74 production scirocco (which is actually a 75 MY, even though production starts in 04/74. but this is a 76MY produced in 75 showing the carpet. ![]() |
jhynesrockmtn Carpet color/pattern correct for 1974 Jun 21 2023, 07:30 PM
r_towle Black
Check World Upholstrey Jun 21 2023, 07:47 PM
Freezin 914 Not sure on BB’s but late 74’s had Grey and Bl... Jun 21 2023, 08:07 PM
87m491 Mine looks just like this. At least it did until ... Jun 22 2023, 01:21 PM
Jett This is a stock BB carpet… I can get better pics... Jun 21 2023, 08:11 PM
scallyk9
This is a stock BB carpet… I can get better pic... Jun 22 2023, 12:43 PM
wonkipop
This is a stock BB carpet… I can get better pi... Jun 22 2023, 04:42 PM
JeffBowlsby Great thread. The LEs did have two different blac... Jun 22 2023, 01:16 PM
wonkipop my jan 74 car (not a SE) has the loop pile that @... Jun 22 2023, 04:32 PM
dr914@autoatlanta.com german loop is probably the closest a purpleish bl... Jun 22 2023, 05:07 PM
jhynesrockmtn
german loop is probably the closest a purpleish b... Jun 23 2023, 08:17 PM
wonkipop @jhynesrockmtn
i took a scan back through the fi... Jun 23 2023, 03:19 PM
Freezin 914 My car is a 74 2.0, I will check and confirm build... Jun 23 2023, 05:26 PM
wonkipop digging through my L jet files a bit closer it loo... Jun 23 2023, 08:39 PM
wonkipop here are some more for you @jhynesrockmtn
i had... Jun 23 2023, 09:00 PM
JeffBowlsby A quick review of the 914 LE archives indicates th... Jun 23 2023, 10:46 PM
wonkipop
A quick review of the 914 LE archives indicates t... Jun 24 2023, 04:51 PM
wonkipop as an aside @JeffBowlsby and not off topic when... Jun 24 2023, 05:32 PM
jhynesrockmtn So, in summary @wonkipop , [b]@[url=http://www.9... Jun 25 2023, 01:18 PM
Jett
So, in summary [b]@[url=http://www.914world.com/... Jun 25 2023, 02:41 PM
wonkipop
So, in summary [b]@[url=http://www.914world.com/... Jun 25 2023, 05:03 PM
L-Jet914
So, in summary [b]@[url=http://www.914world.com... Jun 30 2023, 07:31 PM
Mikey914 Learn something everyday.
I have a pretty much ... Jun 25 2023, 03:36 PM
JeffBowlsby That’s the later carpet. ‘Salt & pepperâ€... Jun 30 2023, 09:10 PM
wonkipop
That’s the later carpet. ‘Salt & pepperâ... Jul 1 2023, 03:20 AM
Mikey914 I was a little surprised, but yes the salt and p... Jun 30 2023, 10:16 PM
wonkipop @JeffBowlsby [b]@[url=http://www.914world.com/b... Jul 1 2023, 03:31 AM
Mikey914 To be clear, if you order the salt and pepper off ... Jul 1 2023, 10:35 AM
JeffBowlsby In RE: the carpets for the black bumblebees &c... Jul 1 2023, 03:36 PM
cholland_
as a side note the scirocco, golf and passat (rab... Jul 4 2023, 12:45 PM
r_towle
as a side note the scirocco, golf and passat (ra... Jul 4 2023, 04:15 PM
wonkipop
[quote name='cholland_' post='3087366' date='Jul ... Jul 4 2023, 05:59 PM
wonkipop
[quote name='wonkipop' post='3086913' date='Jul 1... Jul 4 2023, 04:46 PM
cholland_
as noted in the post i have never been able to fi... Jul 5 2023, 09:57 AM
wonkipop
as noted in the post i have never been able to f... Jul 5 2023, 05:37 PM
wonkipop
as noted in the post i have never been able to f... Jul 5 2023, 05:42 PM
wonkipop
Very interesting about the plastic fuel tank... Jul 5 2023, 06:05 PM
Mikey914 You know what's really funny, my 1st car was ... Jul 2 2023, 01:07 PM
wonkipop
You know what's really funny, my 1st car was... Jul 2 2023, 04:44 PM
Van B Timely conversation, I’m a couple days late, but... Jul 3 2023, 01:19 PM
wonkipop
Timely conversation, I’m a couple days late, bu... Jul 3 2023, 04:41 PM
Van B Ok. So, not much value added then lol…
Too bad ... Jul 3 2023, 05:54 PM
wonkipop
Too bad... Jul 3 2023, 07:11 PM
StarBear Yep; just exactly like my old ones! Original t... Jul 3 2023, 06:03 PM
r_towle For the carpet, ask
World Upholstrey
Worlduph.com... Jul 4 2023, 04:21 PM
wonkipop @cholland
this is about the best i can find on re... Jul 4 2023, 05:35 PM
wonkipop on a less esoteric historical level :D and gettin... Jul 4 2023, 10:28 PM
JeffBowlsby 928s do have plastic fuel tanks, they are a thick,... Jul 5 2023, 10:10 AM
wonkipop communication from deep down the rabbit hole.
(i h... Jul 7 2023, 03:12 AM
wonkipop and here is one from the bottom of the seabed.
sur... Jul 7 2023, 03:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:11 PM |
