| jhynesrockmtn |
Jun 21 2023, 07:30 PM
Member ![]() ![]() Group: Members Posts: 447 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest
Hi, working away on a refresh of some items on my Bumblebee. One of the items I want to address is the cheap carpet kit it has that has not been installed very well to boot.
I am going to place an order for a kit. The question is which color. I want to go with the German Loop. There is a black, early charcoal and late charcoal. Which color is the most appropriate for a Bumblebee with a black interior. ![]() |
| Van B |
Jul 3 2023, 05:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
Ok. So, not much value added then lol…
Too bad there’s no way to get a heat formed replacement. I was optimistic that the original carpet would clean up, but the passenger side just won’t clean up I’m not a fan of gluing things that can trap water |
| wonkipop |
Jul 3 2023, 07:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Ok. So, not much value added then lol… Too bad there’s no way to get a heat formed replacement. I was optimistic that the original carpet would clean up, but the passenger side just won’t clean up I’m not a fan of gluing things that can trap water all confirmation is value. you are lucky if you can refit the original carpet being left hand drive. i have a similar view re glueing carpet but had little choice since rhd stuff i had to do is "fake - only way i could do rhs hand brake sill was to glue down. i was a little more tactical with the tunnel piece and only glued it enough to hold it along edges so i can get it up easy to do any tunnel work if it have to. though i recall the passenger side sill carpet was originally glued and the wheel well pieces along with the bit right up under dashboard above pedal box. but its a long time ago i took those out. so probably wrong memory. i think the idea of the heat formed pieces is that they were always intended to be easily removable for dealer mechanics to do service work on hand brake and to get tunnel access. |
jhynesrockmtn Carpet color/pattern correct for 1974 Jun 21 2023, 07:30 PM
r_towle Black
Check World Upholstrey Jun 21 2023, 07:47 PM
Freezin 914 Not sure on BB’s but late 74’s had Grey and Bl... Jun 21 2023, 08:07 PM
87m491 Mine looks just like this. At least it did until ... Jun 22 2023, 01:21 PM
Jett This is a stock BB carpet… I can get better pics... Jun 21 2023, 08:11 PM
scallyk9
This is a stock BB carpet… I can get better pic... Jun 22 2023, 12:43 PM
wonkipop
This is a stock BB carpet… I can get better pi... Jun 22 2023, 04:42 PM
JeffBowlsby Great thread. The LEs did have two different blac... Jun 22 2023, 01:16 PM
wonkipop my jan 74 car (not a SE) has the loop pile that @... Jun 22 2023, 04:32 PM
dr914@autoatlanta.com german loop is probably the closest a purpleish bl... Jun 22 2023, 05:07 PM
jhynesrockmtn
german loop is probably the closest a purpleish b... Jun 23 2023, 08:17 PM
wonkipop @jhynesrockmtn
i took a scan back through the fi... Jun 23 2023, 03:19 PM
Freezin 914 My car is a 74 2.0, I will check and confirm build... Jun 23 2023, 05:26 PM
wonkipop digging through my L jet files a bit closer it loo... Jun 23 2023, 08:39 PM
wonkipop here are some more for you @jhynesrockmtn
i had... Jun 23 2023, 09:00 PM
JeffBowlsby A quick review of the 914 LE archives indicates th... Jun 23 2023, 10:46 PM
wonkipop
A quick review of the 914 LE archives indicates t... Jun 24 2023, 04:51 PM
wonkipop as an aside @JeffBowlsby and not off topic when... Jun 24 2023, 05:32 PM
jhynesrockmtn So, in summary @wonkipop , [b]@[url=http://www.9... Jun 25 2023, 01:18 PM
Jett
So, in summary [b]@[url=http://www.914world.com/... Jun 25 2023, 02:41 PM
wonkipop
So, in summary [b]@[url=http://www.914world.com/... Jun 25 2023, 05:03 PM
L-Jet914
So, in summary [b]@[url=http://www.914world.com... Jun 30 2023, 07:31 PM
Mikey914 Learn something everyday.
I have a pretty much ... Jun 25 2023, 03:36 PM
JeffBowlsby That’s the later carpet. ‘Salt & pepperâ€... Jun 30 2023, 09:10 PM
wonkipop
That’s the later carpet. ‘Salt & pepperâ... Jul 1 2023, 03:20 AM
Mikey914 I was a little surprised, but yes the salt and p... Jun 30 2023, 10:16 PM
wonkipop @JeffBowlsby [b]@[url=http://www.914world.com/b... Jul 1 2023, 03:31 AM
Mikey914 To be clear, if you order the salt and pepper off ... Jul 1 2023, 10:35 AM
JeffBowlsby In RE: the carpets for the black bumblebees &c... Jul 1 2023, 03:36 PM
wonkipop @Mikey914
you have to be cautious these days mat... Jul 1 2023, 09:05 PM
cholland_
as a side note the scirocco, golf and passat (rab... Jul 4 2023, 12:45 PM
r_towle
as a side note the scirocco, golf and passat (ra... Jul 4 2023, 04:15 PM
wonkipop
[quote name='cholland_' post='3087366' date='Jul ... Jul 4 2023, 05:59 PM
wonkipop
[quote name='wonkipop' post='3086913' date='Jul 1... Jul 4 2023, 04:46 PM
cholland_
as noted in the post i have never been able to fi... Jul 5 2023, 09:57 AM
wonkipop
as noted in the post i have never been able to f... Jul 5 2023, 05:37 PM
wonkipop
as noted in the post i have never been able to f... Jul 5 2023, 05:42 PM
wonkipop
Very interesting about the plastic fuel tank... Jul 5 2023, 06:05 PM
Mikey914 You know what's really funny, my 1st car was ... Jul 2 2023, 01:07 PM
wonkipop
You know what's really funny, my 1st car was... Jul 2 2023, 04:44 PM
Van B Timely conversation, I’m a couple days late, but... Jul 3 2023, 01:19 PM
wonkipop
Timely conversation, I’m a couple days late, bu... Jul 3 2023, 04:41 PM
StarBear Yep; just exactly like my old ones! Original t... Jul 3 2023, 06:03 PM
r_towle For the carpet, ask
World Upholstrey
Worlduph.com... Jul 4 2023, 04:21 PM
wonkipop @cholland
this is about the best i can find on re... Jul 4 2023, 05:35 PM
wonkipop on a less esoteric historical level :D and gettin... Jul 4 2023, 10:28 PM
JeffBowlsby 928s do have plastic fuel tanks, they are a thick,... Jul 5 2023, 10:10 AM
wonkipop communication from deep down the rabbit hole.
(i h... Jul 7 2023, 03:12 AM
wonkipop and here is one from the bottom of the seabed.
sur... Jul 7 2023, 03:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:19 PM |
