123 ignition pros -cons ? |
jims914 |
Apr 3 2023, 11:15 PM
Member Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region |
Anyone have any Pros or Cons for a 123 ignition D-jet tune-4-r-v-p unit for 74 2.0 ?
Lockwodo |
Oct 28 2023, 07:10 PM
Member Group: Members Posts: 202 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
This is how I programmed the 123 centrifugal curve on my '74 2.0, and it seems to work great:
I've experimented a bit with the MAP curve to add a little vacuum advance under load, but haven't figured it out yet, so for now am just running the centrifugal curve. Would be interested in hearing from anyone who is using the MAP curve successfully. |
VaccaRabite |
Nov 1 2023, 06:30 AM
En Garde! Group: Admin Posts: 13,466 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
This is how I programmed the 123 centrifugal curve on my '74 2.0, and it seems to work great: I've experimented a bit with the MAP curve to add a little vacuum advance under load, but haven't figured it out yet, so for now am just running the centrifugal curve. Would be interested in hearing from anyone who is using the MAP curve successfully. @lockwodo I bet it would work even better if you advanced it to about 8* at 1000. That will give you a little more bite as you are getting off idle. Zach |
Lockwodo |
Nov 1 2023, 04:49 PM
This is how I programmed the 123 centrifugal curve on my '74 2.0, and it seems to work great: I've experimented a bit with the MAP curve to add a little vacuum advance under load, but haven't figured it out yet, so for now am just running the centrifugal curve. Would be interested in hearing from anyone who is using the MAP curve successfully. @lockwodo I bet it would work even better if you advanced it to about 8* at 1000. That will give you a little more bite as you are getting off idle. Zach Thanks Zach, I'll try that! Doug |
Lo-Fi Version | Time is now: 17th June 2024 - 12:42 PM |
