60mm AFR Gauge - "Gauging" Interest |
jbell959 |
Dec 4 2023, 10:42 AM
Newbie Group: Members Posts: 3 Joined: 2-May 21 From: CA Member No.: 25,505 Region Association: None |
As some of you may know, I build an 80mm custom AFR gauge as a clock replacement for 911s and recently someone asked me if it was possible to build a 60mm version. I was able to fit the main board and stepper movement in a 60mm case. This is just a prototype, but it does appear that with a little work, I could make these. It would require a 60mm temp or volt gauge as the donor to get the case, face, and needle. I don't yet have an estimate on the cost, but I wanted to see if there would be any interest before I spend more time on it.
Like all of my other AFR solutions, this gauge would work with most wideband controllers including but not limited to AEM, Innovate, PLX, and 14Point7. Sorry for the blurry picture! Attached thumbnail(s) |
Montreal914 |
Dec 4 2023, 11:54 AM
Senior Member Group: Members Posts: 1,590 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Nice option! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/popcorn[1].gif)
What would be incredibly awesome would be a Cylinder Head Temperature gauge with a nice scale span (250-450F) like the 60mm MBZ outside temperature gauge (picture below). I have been thinking about how one could be transformed to achieve this. Or use a cheap K-type TC reader board that puts out 0-5V and convert that 0-5V into some scale using a VDO movement. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 09:47 AM |
