> Threshold Plastic Rivet Suggestions
Literati914
post Dec 9 2023, 04:21 PM
I bought a set of the plastic expanding "push" rivets from 914rubber - and they're a bit of a nightmare TBH. Their pins are wayyy too tight as they come, and my install ratio keep decreasing. Pins will not turn by hand or otherwise, and mostly just end up breaking when trying to tap them in. Anyone got suggestions for working with these?
Literati914
post Dec 10 2023, 07:27 PM
QUOTE(technicalninja @ Dec 9 2023, 07:18 PM) *
Super clean the holes out.?
I could get the rivets in the holes just fine, the soft flimsy pins though will mostly give before they'd move and not move at all. They're too tight leaving you with a destroyed rivet. And that's tapping very gently with a smallish cobbler's hammer (learned after the first one that soft coaxing would be needed). I was successful on two of the six that I tried. Hopefully you guys have better luck!
QUOTE(gereed75 @ Dec 9 2023, 08:32 PM) *
I recently bought a set from 914 and they were very soft plastic and there was no way I could insert them. Found some in McMaster that will work but will require slightly larger holes.
The McMaster ones are very close dimensionally and in appearance to the original just slighty larger.
I'm gonna look over there - Thanks!
Literati914   Threshold Plastic Rivet Suggestions   Dec 9 2023, 04:21 PM
914sgofast2   Try Grainger Supply for black plastic rivets.   Dec 9 2023, 04:50 PM
76-914   I bought a set of the plastic expanding "pus...   Dec 9 2023, 07:10 PM
Front yard mechanic   Just drill them clear   Dec 9 2023, 07:18 PM
technicalninja   A little disturbing from my viewpoint. I have a s...   Dec 9 2023, 07:18 PM
gereed75   I recently bought a set from 914 and they were ver...   Dec 9 2023, 08:32 PM
mlindner   just use metal rivets, many sizes and also in blac...   Dec 10 2023, 07:25 AM
rick 918-S   Mark is going to want to know about this.   Dec 10 2023, 08:37 AM
StarBear   Here’s what I do : clip the rod very close to t...   Dec 10 2023, 12:32 PM
Olympic 914   Here’s what I do : clip the rod very close to ...   Dec 10 2023, 01:52 PM
Nate W   I insert the plastic rivet, holding the pin with s...   Dec 10 2023, 05:33 PM
Literati914   .. Super clean the holes out.? I could get the ...   Dec 10 2023, 07:27 PM
Literati914   Here’s what I do : clip the rod very close to ...   Dec 10 2023, 07:33 PM
Mikey914   The way to install these is not intuitive. Snap o...   Dec 11 2023, 11:34 PM
87m491   The way to install these is not intuitive. Snap ...   Dec 12 2023, 07:41 AM
dr914@autoatlanta.com   the aftermarket ones are too big, only the factory...   Dec 12 2023, 10:16 AM
NARP74   Are the rivets metric? I never checked. Are they...   Dec 12 2023, 10:48 AM
TonyA   What color should they be. Clear plastic or black?   Dec 12 2023, 12:44 PM
rgalla9146   What color should they be. Clear plastic or black...   Dec 12 2023, 03:22 PM
Montreal914   Why would a German car have non-metric fasteners? ...   Dec 12 2023, 12:48 PM
NARP74   Why would a German car have non-metric fasteners?...   Dec 12 2023, 06:35 PM
pek771   I think the only non-metric stuff in a Porsche or ...   Dec 12 2023, 07:14 PM
- Lo-Fi Version Time is now: 3rd September 2025 - 06:31 PM
