Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,087 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
I bought a set of the plastic expanding "push" rivets from 914rubber - and they're a bit of a nightmare TBH. Their pins are wayyy too tight as they come, and my install ratio keep decreasing. Pins will not turn by hand or otherwise, and mostly just end up breaking when trying to tap them in. Anyone got suggestions for working with these?
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The way to install these is not intuitive.
Snap off the pun, fluo it over and push it into the rivet section. Its pretty easy if you do it this way. I have never been able to tap it straight in, its allways slighty off, starting it manually is the only way to go.. |
87m491 |
Member ![]() ![]() Group: Members Posts: 330 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States ![]() ![]() |
The way to install these is not intuitive. Snap off the pun, fluo[b][u] it over and push it into the rivet section. Its pretty easy if you do it this way. I have never been able to tap it straight in, its allways slighty off, starting it manually is the only way to go.. Where's autocorrect when you need it? Gotta ask as my 914R rivets have been waiting for my threshold trim to arrive. Are you saying insert the pins into the bottom of the rivet before then inserting the rivet into the hole? (assumed that you insert far enough so some sticks out the top and then will be tapped down for final fitment? |
Lo-Fi Version | Time is now: 3rd September 2025 - 06:30 PM |
