| Gatornapper |
Oct 7 2023, 06:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,293 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States
The first part of my purchase and rebuild/restoration of my '76 914 is in Virginia Teener but I thought I should put Phase II in a 2nd thread.
In review, maybe I should recap the basics of Phase I started in Sept. of 2017. I'll try to do a condensed version: Car was abandoned in good friend's barn in 2005 an hour from where I live west of Richmond, VA. Friend asked me to buy it from the owner - another friend - who refused to move it. ME: "Sorry don't want a 914. They are VW's that are rust-buckets." FRIEND: "It's in really good condition and was running perfectly when parked in 2005. You should at least come look at it." I did, body was in very good condition with little rust. Found out after purchase it was an LA car (sold in Placenta). Owner raced 911's & 914's, wanted $7k. No way, offered $3k. He took it, albeit with much grumbling & griping. Driving home with 914 on my car trailer I wondered, 'What in the world have I gotten myself into?" I had never driven a 914 and knew so little about them. This forum was my 914 'salvation'. Everyone here has been incredibly helpful from day 1 and I have no words for my appreciation for all of you. Car's condition: The good: 911 Master cylinder, BMW 320i front brakes, little rust, car super-tight. Paint a 1st class job, but oxidized on lids. New rack & pinion. Scotty Burnett inspects car - says one of most rust-free 914's he's ever seen. The bad: Tank ouf of car, badly corrupted. Carbs horrible from years of gas left in them - almost beyond recovery. Dead battery. Tires shot. Rear brakes seized. It was about a year's work to get car on road. Long list of work: Rebuilt carbs 3x. New jets, new idle jets. Studied book on Weber's. I'm pretty good carb guy, but never seen Weber's. Had dual IDF-44's which everyone said were too big for everyday driving. (Local Porsche dealer installed the carbs at PO's request, telling him they were too big.) New fuel lines. All new ignition including EI. Dizzy was 009. New rear brakes from PMB/Eric. New racing front brake pads made huge difference. Other help from Eric too - thank you. Complete flush of all brake lines. New tires. Got car running and just driving up my 1/2 mile drive at 15mph - I knew I had a phenomenal car and was ecstatic. Handling blew me away. Took me a year to dial in the carbs. Finally got 44's running great for every day driving, but a bit louder than I like. Oh, well. Drove car for 4 years/6k miles, loving it. Worked on tons of details: Found/installed 050 dizzy - thank you Brant - and car's running and performance improved noticeably. Replace many pieces of trim/visors, etc. Thank you 914rubber.com/Mike. Dr. Phil gave me his like new 75 front bumper - mine was trash. Also sold me OEM Fog Lights - dramatically improving ugliness of big black front bumper. Rick Berkowitz - local 914 friend/Porsche encyclopedia helped me with a million things, lots of pieces and parts including a nice front spoiler. Found & had powder-coated nice set of original Mahle's that tranformed the car. All new shift bushings. Welded/closed lots of rusted thru areas on muffer, repaired issues with heat exchangers. New Relay Board & relays, starter, alternator. New ThunderSpark plug wires. New fuel tank, new stainless fuel lines installed. Installed fuel pressure regulator & gauge in engine bay to keep pressure precisely at 3 psi for Weber's. New thermostat from Tangerine Racing. New tail light bezels - European from Sierra Madre. Sorry - my preference. Installed LED headlights, all LED's in all other lights. Powder-coated engine tins. Tons of other minor items fixed/repaired/renewed. This was Phase I. Started Phase II on August 5th, 2022. GN PS: I must say thank you to George as well. He's always been available for my incessant questions - while always screaming about how the 44's will ruin my engine by running too rich. At the same time I've sure sent a lot of money to Auto Atlanta over the last 6 years...... ;-) |
| Gatornapper |
Jan 31 2024, 10:13 AM
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) My Ruby 914 (antique plates coming soon) could not be running or shifting better! And I love the Malaga Red more every day. The old Scarlet Red bugged me every time I drove the car......... This is a 7 year old dream come true! First broke engine in with an easy 100 miles, no loads, 2,000 to 3,000 rpm at most. Changed oil and filter. Now have been pushing her hard on hills to seat the rings but no more than 3,500 rpm for a hundred miles, then no more than 4,000. Almost 350 miles on engine since rebuild. Could not be running smoother. I'm amazed at the torque I have between 3,000 and 4,000 rpm. She is pulling strong. Not exceeding 4,000 rpm until about 1,000 miles. Need to dial down idle a bit still - she's about 1,400 now most of the time but after an hour of running drops to about 1,100. Biral cylinders running nice and cool. But then, it is cool outside. I'm looking forward to see how they do in the heat. Will do another oil & filter change after 600 total miles (100 easy break-in, then 500 with some loads), and also adjust the valves. They seem good for now, but sure they will need it at 600. Will keep you all posted along the way, GN |
Gatornapper Phase II of my Restoration of my '76 914 Oct 7 2023, 06:50 PM
Gatornapper Phase II of my 914 restoration has been part of my... Oct 7 2023, 07:18 PM
76-914 I would heed George's advice re: those 44... Oct 8 2023, 10:50 AM
Gatornapper I hear you. Will be adjusting them using AFR mete... Oct 12 2023, 07:19 PM
Gatornapper The plan is also to put the original D-Jet back on... Oct 12 2023, 07:54 PM
Gatornapper HUGE DAY YESTERDAY! ENGINE IN THE 914! ... Oct 12 2023, 07:29 PM
Front yard mechanic Nice looking engine / transmission and garage itâ€... Oct 13 2023, 07:11 AM
Gatornapper Somewhat true. EVERY wall is either shelf, cabine... Oct 13 2023, 07:43 PM
Gatornapper I apologize for lack of posts and pics of my Phase... Dec 28 2023, 03:16 PM
Gatornapper New EMPI 40 (IDF-40 clone) carbs, 123ignition Dist... Dec 28 2023, 03:23 PM
Cairo94507 :trophy: :popcorn: :beer2: Dec 28 2023, 04:32 PM
Root_Werks Looks clean!
Best of luck with the start up... Dec 28 2023, 05:33 PM
Gatornapper Cairo94507 & Root_Werks -
THANKS GUYS!
G... Dec 28 2023, 06:37 PM
THANKS GUYS!
Gatornapper Started the engine tonight - and wow! It has ... Dec 28 2023, 06:32 PM
Gatornapper Some tranny rebuild pics I should have posted long... Jan 1 2024, 07:06 AM
Gatornapper Replaced bad Loose Gear Wheel - 1st gear (center),... Jan 1 2024, 07:29 AM
Gatornapper Small other part - old Pedal Board was cracked ... Jan 1 2024, 07:39 AM
Gatornapper HAPPY HAPPY NEW YEAR everyone!
Hope this is y... Jan 1 2024, 07:51 AM
Gatornapper Spent day working on pulling out old carpet to rep... Jan 3 2024, 06:13 PM
Gatornapper My son who can bench press 400 lbs. and cycle 100 ... Jan 3 2024, 08:24 PM
Gatornapper NTM brown door vinyl transferred to new door cards... Jan 4 2024, 08:06 PM
Gatornapper :Qarl: :Qarl: :Qarl:
:driving: :driving: :d... Jan 6 2024, 01:37 PM
Gatornapper :headbang: :headbang: :headbang:
Well, all w... Jan 8 2024, 04:29 PM
dax1969
Sad to hear this, hope you have no further inter... Jan 9 2024, 04:28 AM
Gatornapper Dax -
Thanks for the encouragement - glad to hear... Jan 9 2024, 07:36 AM
Cairo94507 @Gatornapper - I hope you get this addressed and ... Jan 9 2024, 08:31 AM
Gatornapper Thanks bro!
The best news is how the engine i... Jan 9 2024, 04:35 PM
Gatornapper Nothing wrong with linkage - new brass/bronze bush... Jan 9 2024, 05:07 PM
Dlee6205 I'm not saying its necessarily related to your... Jan 9 2024, 07:38 PM
Gatornapper Doug -
AH! Thank you! Circlip goes on o... Jan 9 2024, 07:42 PM
Gatornapper My Bad! I see it here and can't wait to c... Jan 9 2024, 07:56 PM
worn Good luck! You have been inspiring. I hope m... Jan 9 2024, 09:17 PM
Gatornapper Thanks Worn!
Haven't messed with alligato... Jan 10 2024, 06:40 AM
Gatornapper Bushing corrected. Made no difference in 4/5.
Wh... Jan 10 2024, 01:54 PM
Gatornapper [b]DROPPING TRANNY WITHOUT DROPPING ENGINE
As I s... Jan 11 2024, 05:18 PM
Gatornapper Tranny out last night, pulled apart this AM. Bolt... Jan 12 2024, 11:38 AM
Gatornapper 90% sure I've found the problem.
Angle off a ... Jan 14 2024, 08:25 AM
Gatornapper HALLELUJAH! TODAY WAS THE DAY!
:Qarl:... Jan 25 2024, 07:19 PM
dstudeba Looks great! Congrats on getting back on the ... Jan 25 2024, 07:57 PM
Root_Werks Wonderful news! Good sleuthing on your part w... Jan 26 2024, 11:28 AM
Gatornapper CARS & COFFEE - Richmond, VA Sat. 2/3/24
Rick... Feb 3 2024, 02:08 PM
Gatornapper SHOW & TELL TIME!
Perfect day for glamour... Feb 3 2024, 02:31 PM
Gatornapper NOTE:
Interesting feature of Malaga Red.
Only co... Feb 3 2024, 05:00 PM
Jett Great looking car! Feb 3 2024, 10:08 PM
bkrantz Nice! Feb 3 2024, 10:15 PM
Gatornapper Thanks guys!
JUST CAME TODAY! Too bad p... Feb 5 2024, 06:58 PM
Gatornapper Finally got the repaired brown rear panel installe... Feb 22 2024, 08:26 PM
Gatornapper Wow. I thought she was running great and had a gr... Feb 27 2024, 05:27 PM
Gatornapper WHO NEEDS A SIX?
I SURE DON'T!
GN
(Forg... Feb 27 2024, 05:31 PM
Gatornapper Another surprising tweak in engine performance and... Mar 1 2024, 09:01 PM
jhynesrockmtn Just read through this today. What an inspiring t... Mar 2 2024, 08:13 AM
Gatornapper Wow. Thank you. One of nicest posts I've rec... Mar 2 2024, 08:03 PM
Gatornapper Happy Father's Day to all the Dad's out th... Jun 16 2024, 06:24 PM
worn
Happy Father's Day to all the Dad's out t... Jun 16 2024, 07:59 PM
Gatornapper The paint job is indeed superb and exceptional - b... Jun 20 2024, 08:13 AM
Geezer914 Love that color red! Jun 20 2024, 12:05 PM
Gatornapper So do I!
I've said it before, but it bear... Jun 20 2024, 03:20 PM
Root_Werks Very cool to see the updates and the 914 looks ama... Jun 20 2024, 04:05 PM
Gatornapper Dan -
Boy, you nailed it! Love this car so m... Jun 20 2024, 07:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 04:36 PM |
