| Cal |
Feb 4 2017, 01:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I recently purchased an original exhaust for my '74 2.0L that's in excellent condition. I was thinking of using the VHT SP104 high heat flat grey paint to finish it off....any advise on other paints that I should consider?
I'm also going to repaint the heater control flaps, boxes and pipes in satin black.....do those need high heat paint as well? Attached thumbnail(s) |
| mb911 |
Mar 3 2024, 04:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,730 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Big fan of cerakote but I can tell you my favorite paint for exhaust that matches OEM is rustoleum 2000 degree primer.
| porschetub |
Mar 4 2024, 10:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,065 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Using the same VHT product ,well pleased with it and no burn or corrosion on the hot spots, used this paint on a preheated clean muffler but IMO prep is key to getting it to last .
Cleaned all the old coating off and wire buffed till the whole thing was shiny then used emery tape to help key the paint on the surface,warm day but nuked it with my heatgun,did this on every coat ..looks great and lasting well cheers. |
Cal Exhaust paint Feb 4 2017, 01:47 PM
914Next
I recently purchased an original exhaust for my ... Feb 4 2017, 02:01 PM
Tom_T Congratz on the find Jeff! Is it the Leistrit... Feb 4 2017, 02:22 PM
Tom_T Jeff, see the PM I just sent you on this.
Stoddar... Feb 4 2017, 02:57 PM
914Sixer I ordered exhaust paint from Stoddard in November ... Feb 4 2017, 03:32 PM
Tom_T Jeff,
FYI - per my PM, here's a close-up pic... Feb 9 2017, 06:44 PM
dcheek I've used the VHT SP-104 for years. It doesn... Feb 10 2017, 08:00 AM
Mark Henry I've had the best luck with black BBQ/wood sto... Feb 10 2017, 10:14 AM
914Sixer Talked to Stoddard yesterday, they no longer have ... Feb 11 2017, 07:15 AM
Cal
Talked to Stoddard yesterday, they no longer have... Feb 11 2017, 08:44 AM
Tom_T
Talked to Stoddard yesterday, they no longer hav... Feb 11 2017, 12:06 PM
Krieger I used 3m Weld Through on my stock 911 muffler. I... Feb 11 2017, 08:50 AM
Tom_T
I used 3m Weld Through on my stock 911 muffler. ... Feb 11 2017, 12:12 PM
Cal Update.....I ended up using the VHT SP100 primer a... Apr 3 2017, 08:15 PM
Tom_T That looks real nice Jeff!
:beer2:
Tom
/////... Apr 3 2017, 08:25 PM
Jett Great job, looks clean.
...also motivating me to ... Apr 3 2017, 08:28 PM
Lucky9146 I don't know if you considered it but I cerami... May 4 2017, 03:21 PM
Tom_T For those looking for a PC or Ceramic option close... May 4 2017, 03:52 PM
horizontally-opposed You might try West Coast Powder at 925 682-4828. I... May 4 2017, 04:55 PM
mb911 Look up cerakote. Its a ceramic paint and is high ... May 5 2017, 05:25 AM
Jett :) I used stoddard grey on my 1.7 muffler and cera... May 5 2017, 08:31 AM
Matty900
:) I used stoddard grey on my 1.7 muffler and cer... May 6 2017, 12:48 AM
Tom_T
I just dropped my heat exchangers and muffler off... May 6 2017, 12:28 PM
moorepower I would use Tech Line Coatings Black Satin. Coat t... May 7 2017, 09:30 AM
DennisV Has anyone sprayed the Wurth High Heat Aluminum Pa... Mar 2 2024, 11:57 AM
mepstein The oem 914-6 flapper boxes that I’ve seen were ... Mar 2 2024, 12:41 PM
Ishley I’m a fan of cerekote. Withstands the heat and l... Mar 2 2024, 08:39 PM
nivekdodge I just did Cerakote's
air dry on my exhaust a... Mar 2 2024, 10:03 PM
rick 918-S I have some galvanizing spray paint I picked up at... Mar 3 2024, 07:16 AM
barefoot I did my 911 parts with Jet cote some yrs ago look... Mar 5 2024, 12:07 PM
Krieger So how have your paint choices held up? Rustoleum... Jan 14 2026, 09:27 PM
mb911
So how have your paint choices held up? Rustoleu... Jan 17 2026, 03:24 PM
rgalla9146 The one on the car was shot early summer and has s... Jan 17 2026, 05:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:08 PM |
