> “Headers” for a 4?
Freezin 914
post Apr 22 2024, 12:00 PM
Hello, I am considering buying a set of Dansk race tubes or a set of Bursch x pipe headers for my 2.0. Does anyone here have any experience with either of these?
I don’t need heat in my car. Planning to remove exchangers and dampers under the car for easier access for maintenance etc.
Is one better than the next? Both are stainless construction…..anybody with direct knowledge or experience? I would love to learn more about these.
Also, best way to cap heater tubes as they exit body…. Need to keep critters and road debris out!!!
Thanks.
VaccaRabite
post Apr 22 2024, 12:11 PM
En Garde!
IMO, if you don't need heat you open up so many better options for actual headers.
The DANSK tubes are expensive and leave you with the same limitations of heat exchangers without any of the upside.
Eurorace costs about the same, gets you an actual 4-1 collector and stub connectors.
Tangerine costs a little more, and is a lot nicer of a system.
MSD gets you a stout system that is very customizable.
All of these are way better then the DANSK tubes.
Zach
JamesM
post Apr 28 2024, 08:22 PM
QUOTE(VaccaRabite @ Apr 22 2024, 10:11 AM) *
Tangerine costs a LOT more than any of the other options, also good chance it might take a while to get it as Chris is a one man shop. Was over 18 months from time of ordering to get mine. That said they are far nicer, the only header option with some availability of heat, and the only tuned 4-2-1 setup you can get.
Euro race makes good power over a stock setup but mine always leaked at the collector, tried everything for years and then just gave up and ordered a Tangerine system. Granted I have an older eurorace setup with springs on the collector vs bolts that the newer ones seem to have, with a slip fit 4-1 collector though I suspect it may still be an issue.
A local guy has the MSDS setup, no leaks but as stated doesnt have stubs, and with the way all header systems merge both sides of the engine crossing under the case/trans requiring to pull the exhaust more than you might a stock setup, its REALLY nice to have stubs.
Freezin 914   “Headers” for a 4?   Apr 22 2024, 12:00 PM
VaccaRabite   IMO, if you don't need heat you open up so man...   Apr 22 2024, 12:11 PM
Freezin 914   IMO, if you don't need heat you open up so ma...   Apr 22 2024, 12:37 PM
JamesM   Eurorace costs about the same, gets you an actua...   Apr 28 2024, 08:22 PM
GregAmy   Tangerine costs a LOT more than any of the other o...   Apr 29 2024, 11:51 AM
ChrisFoley   I'm guessing you'll get one a lot faster...   Apr 30 2024, 06:04 AM
JamesM   James' order came at a time of peak disorder...   Apr 30 2024, 03:08 PM
JamesM   @ChrisFoley Im a bit of a data nerd and really i...   Apr 30 2024, 03:21 PM
mepstein   Get some plastic caps from a paint can or similar ...   Apr 22 2024, 12:11 PM
infraredcalvin   Get some plastic caps from a paint can or similar...   Apr 28 2024, 10:52 AM
Shivers   Hello, I am considering buying a set of Dansk rac...   Apr 22 2024, 12:18 PM
barnfind9141972   I have a set of headers from Marty from MSDS and t...   Apr 28 2024, 12:40 AM
moto914   I have a set of headers from Marty from MSDS and ...   Apr 28 2024, 09:41 AM
Tdskip   I just installed the Dansk 2.0l exhaust tubes and ...   Apr 28 2024, 12:11 PM
ConeDodger   Chris Foley makes an excellent race tested set up....   Apr 28 2024, 12:28 PM
Freezin 914   Thank you all for the replies so far, still follow...   Apr 29 2024, 05:36 AM
dr914@autoatlanta.com   MSDS is the only four cylinder way to go Hello,...   Apr 29 2024, 11:43 AM
Literati914   I've got this one.. but there's been sever...   Apr 29 2024, 01:45 PM
ChrisFoley   I've got this one.. but there's been seve...   May 2 2024, 03:44 PM
OrangeBones   Hello, I am considering buying a set of Dansk rac...   May 2 2024, 07:29 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:36 PM
