| Freezin 914 |
Apr 22 2024, 12:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 928 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest
Hello, I am considering buying a set of Dansk race tubes or a set of Bursch x pipe headers for my 2.0. Does anyone here have any experience with either of these?
I don’t need heat in my car. Planning to remove exchangers and dampers under the car for easier access for maintenance etc. Is one better than the next? Both are stainless construction…..anybody with direct knowledge or experience? I would love to learn more about these. Also, best way to cap heater tubes as they exit body…. Need to keep critters and road debris out!!! Thanks. |
| VaccaRabite |
Apr 22 2024, 12:11 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
IMO, if you don't need heat you open up so many better options for actual headers.
The DANSK tubes are expensive and leave you with the same limitations of heat exchangers without any of the upside. Eurorace costs about the same, gets you an actual 4-1 collector and stub connectors. Tangerine costs a little more, and is a lot nicer of a system. MSD gets you a stout system that is very customizable. All of these are way better then the DANSK tubes. Zach |
| JamesM |
Apr 28 2024, 08:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Eurorace costs about the same, gets you an actual 4-1 collector and stub connectors. Tangerine costs a little more, and is a lot nicer of a system. Tangerine costs a LOT more than any of the other options, also good chance it might take a while to get it as Chris is a one man shop. Was over 18 months from time of ordering to get mine. That said they are far nicer, the only header option with some availability of heat, and the only tuned 4-2-1 setup you can get. Euro race makes good power over a stock setup but mine always leaked at the collector, tried everything for years and then just gave up and ordered a Tangerine system. Granted I have an older eurorace setup with springs on the collector vs bolts that the newer ones seem to have, with a slip fit 4-1 collector though I suspect it may still be an issue. A local guy has the MSDS setup, no leaks but as stated doesnt have stubs, and with the way all header systems merge both sides of the engine crossing under the case/trans requiring to pull the exhaust more than you might a stock setup, its REALLY nice to have stubs. |
| GregAmy |
Apr 29 2024, 11:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Tangerine costs a LOT more than any of the other options, also good chance it might take a while to get it as Chris is a one man shop. Was over 18 months from time of ordering to get mine. That said they are far nicer, the only header option with some availability of heat, and the only tuned 4-2-1 setup you can get. I'm guessing you'll get one a lot faster now; I was at his shop last week and the list on the wall of pending exhaust builds was down to just one (that list was at LEAST half a dozen pending before Christmas). It is the nicest highest-quality systems I've seen, and sounds excellent. I have a new one for my race car to replace his first-generation system that's on there now, and I am tempted to put that older 25-yr-old system in my street car (I do like having heat though...) Call him. |
| ChrisFoley |
Apr 30 2024, 06:04 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I'm guessing you'll get one a lot faster now; ... James' order came at a time of peak disorder for me. In 2022, the year I turned 65, I just couldn't get motivated to work the extra hours necessary to eliminate a backlog that had built up over the previous 4 years. However, I've done a lot of product development over the past 2 years, including redesigns, and extensive fixture and tooling work. As a result, my more popular items are now easier for me to maintain inventory, and header assembly goes quicker and more smoothly. Somehow I completed 6 full exhaust systems and several mufflers in the past 6 months, completely eliminating my backlog of exhaust work. Going forward, I'm implementing firm production dates for the built-to-order items, at intervals I believe I can keep up with. |
Freezin 914 “Headers” for a 4? Apr 22 2024, 12:00 PM
Freezin 914
IMO, if you don't need heat you open up so ma... Apr 22 2024, 12:37 PM
JamesM
James' order came at a time of peak disorder... Apr 30 2024, 03:08 PM
JamesM @ChrisFoley
Im a bit of a data nerd and really i... Apr 30 2024, 03:21 PM
mepstein Get some plastic caps from a paint can or similar ... Apr 22 2024, 12:11 PM
infraredcalvin
Get some plastic caps from a paint can or similar... Apr 28 2024, 10:52 AM
Shivers
Hello, I am considering buying a set of Dansk rac... Apr 22 2024, 12:18 PM
barnfind9141972 I have a set of headers from Marty from MSDS and t... Apr 28 2024, 12:40 AM
moto914
I have a set of headers from Marty from MSDS and ... Apr 28 2024, 09:41 AM
Tdskip I just installed the Dansk 2.0l exhaust tubes and ... Apr 28 2024, 12:11 PM
ConeDodger Chris Foley makes an excellent race tested set up.... Apr 28 2024, 12:28 PM
Freezin 914 Thank you all for the replies so far, still follow... Apr 29 2024, 05:36 AM
dr914@autoatlanta.com MSDS is the only four cylinder way to go
Hello,... Apr 29 2024, 11:43 AM
Literati914 I've got this one.. but there's been sever... Apr 29 2024, 01:45 PM
ChrisFoley
I've got this one.. but there's been seve... May 2 2024, 03:44 PM
OrangeBones
Hello, I am considering buying a set of Dansk rac... May 2 2024, 07:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:51 AM |
