Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I mostly post on the FB forums, and my FB page as I dont get notifications of replies here and will forget what I posted or responded to. That being said, feel free to contact me directly.
Life has changed in a way over the last few years to enable me more time to work in my shop. My home shop was getting very cramped, and this location 10min from my house opened up and I modified it to be the best space. The floor was a mess, I had to grind it and then prep it for the epoxy floor I put down. I am very happy with the results. I built two rooms in the 2700sf space to add for storage and to keep things looking less crappy. One houses transmission, engine, motorcycle stuff. The other is utility with the compressor, and all of my lifts, and stands, and such. I researched and purchased a single post lift because I didnt want a permanent lift set up in one spot. They are the most expensive of small shop lifts, but I am very happy with the Amgo LMS-7, 7000# lift. If I had it to do over, I would have check out the 6000# one as the 7000# is just a bit too big for the pads to line up with the jack points. I have to use wood on one arm. Not a big deal as I will be lifting heavy stuff, too. Foot print is 89.5'd x 69.5'w. Easy to move. ![]() ![]() The shop space came with a back room already partially walled off, so I closed off one opening and moved all of the cleaning stuff back there; parts washers, laser, sand blaster, vapor hone. I also store transmissions and cases back there for now. Space is getting tight. This is only one rack ![]() Plans had to be modified again as there is a lot of interest in people dropping their whole car off to me for work. I have 2 914/6 in bound, one 911, maybe a second. I also have an 1960 Austin Martin 3000 in the shop for some work. So, two 4 post lifts are inbound to help with storing cars while I work on their drive trains. I already mapped out where they will go to assure they would fit and not be a waste of space. ![]() Pic of the small lounge I made in the front. ![]() I divided the work space in half. Transmission on the right, engines on the left. ![]() ![]() I had a sign cut out of stainless for my logo. Painted some wood to go behind it and last week it was placed. ![]() All in all, pretty great location and lots of support for which I am grateful. I plan to have a grand opening once the lifts are in and all is set up. Tool boxes going over today, so you know its getting real. EvilWerks LLC 467 Wards Corner Rd, Unit A Loveland, OH 45140 By appointment only, unless I am already there, then just stop by. |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,688 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
So cool.....Love it Mike. Best from Wisconsin.
Lo-Fi Version | Time is now: 11th July 2025 - 06:32 AM |
