| Dominic |
Oct 7 2019, 09:44 PM
Dominic ![]() ![]() ![]() Group: Members Posts: 997 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
12/07/2019 UPDATE: SOLD!
11/26/2019 UPDATE: Sale Pending! 10/13/2019 UPDATE: Added more details / info and pictures to the last few posts. For Sale: I have decided to sell my 914-6, I have owned the car almost 5 years and have put less than 1000 miles on it in that time. I have come to the realization that I have too many projects / cars and not enough time. This is an original 6 that was restored several years back with Steel GT flares Paint: Signal Orange (Original Color) Engine: 1970 2.2S MFI engine rebuilt by Denny Aker's in Seattle Exhaust: Stock 914-6 heat exchangers with modified 911 muffler for 2 in / 2 out. Trans: Side Shift transaxle, stock -4 gear ratios, GT Torque Biasing Diff, J-west side shift linkage update Brakes: Front: 911S Alloy Calipers, Rears: 914-6 GT mod with drilled / vented rotors on all four corners Wheels: Fuchs 15x7" Fronts, 15x8" Rears (comes with 15x8" spare) Interior: Momo Prototipo wheel, GTS classic seats with houndstooth inserts, Nakamichi CD player with removable face and aftermarket speaker pods. Body / Exterior: Steel fender flares, steel rocker panels modified for flares, steel front valance modified for flares, GT engine lid built by Sergio Meza, Hella Euro lenses front and rear. Re-chromed front and rear original bumpers with license plate holed welded up on front bumper (high quality chrome work, you have to see these to appreciate how nice they are), new / perfect rubber bumper tops. Original side view mirror (drivers side only) Battery: Odyssey PC680 dry cell battery, rennline battery holder, hella battery cut-off switch, relocated to front trunk (see pics). Original Numbers matching 2.0L longblock included COA included with car along with large folder of records. Asking: $79,000 *Update: 11/12/2019 Lowered price to $75,000. Serious buyers will have to PM me with an actual phone number, internet scammers can F#ck-off (IMG:style_emoticons/default/mad.gif) I will add more pics and details in the coming days. As promised here is a list of items I have replaced since I have owned car. Work Performed Summer 2015: Installed new speedometer cable Installed new J-West side shifter linkage Install late style parking brake handle Installed 944 inertia reel seat belts Installed new Hella Euro front turn signal lenses Replaced front sway bar drop links with adjustable units Replaced front suspension bushings Replace oil pressure sender with new VDO 0-80 psi sender to match gauge Replace fuel tank sending unit with new VDO part Rebuilt pedal cluster with new bronze bushings, new clutch shaft and spring. Replaced right targa bar window seal Replaced Fuel Filler Cap seal Replaced old “914-6” emblem with NOS gold 914-6 script Installed new 12v power adapter under dash (for GPS/phone charger) Repainted petals all four Fuchs wheels with aluminum paint (RSR look) Remove muffler, cleaned, re-welded tail pipe, painted with grey ceramic paint Replaced MFI fuel filter in engine compartment Installed New Rear adjustable Koni shocks with coil over kit (175 lbs springs) Work performed Summer of 2018: Removed engine / Trans / Oil tank / Fuel Tank Installed New front motor mount Installed New Engine Comp Rubber Seals Installed new stainless steel fuel lines through tunnel. Installed new oil supply line from oil tank to engine. Adjusted valves, replaced valve cover gaskets with new silicon units (no leaks) Replaced alternator / alternator belt. Media blasted 11 blade fan and clear coated fan Installed new 123 Ignition programmable blue tooth Distributor Replaced rear brake hosed with new DOT Stainless steel lines. Cleaned and Tested all MFI injectors, replaced one bad injector Installed new IMI Hi-Torque Starter Recent Work Performed: Replaced alloy lug nuts - Oct 2019 Installed new Odyssey PC680 Battery – Oct 2019 Installed New first / Reverse Slider and 1st gear syncro – Oct 2019 Attached thumbnail(s) |
| technicalninja |
Jan 30 2025, 10:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
But shit can happen. Here's an example of what not doing due diligence can result in. Even when BOTH parties used what they believed were "top line" businesses a war ensued. You HAVE to check YOURSELF! You cannot rely on others... A simple "run the seat forward and check for rust" before purchase would have stopped this dumpster fire... http://www.914world.com/bbs2/index.php?showtopic=368857 http://www.914world.com/bbs2/index.php?sho...369454&st=0 Rufus has edited a bunch of stuff. The first post of the sale add used to be a descending price page he was updating every hour or so. MountainRoads will NEVER sell a car again without going through a broker. 3+ years of nothing then that... Educate yourself on what to look for, it's not all that hard. A post asking "What should I look for when I look at a 914 for purchase" will get many replies. Mostly regarding rust... |
Dominic Sold! Signal Orange 1970 914-6, real -6 with steel GT flares, 70' 2.2S MFI engine Oct 7 2019, 09:44 PM
raynekat Looks like a great ride there Dominic.
GLWTS
You ... Oct 8 2019, 12:22 AM
Bruce Hinds WOW - If I could afford a 6 that would be the one... Oct 8 2019, 05:43 AM
Cairo94507 Great looking Six- GLWTS. :beer2: Oct 8 2019, 07:47 AM
pete000 DON'T SELL IT !! Oct 8 2019, 10:12 AM
BuddyV …. original motor … included?
:beer2: Oct 8 2019, 10:44 AM
EdwardBlume
:beer2:
... Oct 9 2019, 07:07 AM
Dominic More pics of Interior... Oct 8 2019, 10:32 PM
Mike Fitton Looks like the Tach and combo gauge are non-origin... Oct 9 2019, 08:09 AM
Dominic
Looks like the Tach and combo gauge are non-origi... Oct 9 2019, 09:00 PM
Rufus This appears to be an awesome 914/6 ... I love it... Oct 9 2019, 11:02 AM
a9146luvr If this is a "/car" that you are selling... Oct 9 2019, 11:30 AM
JOEPROPER
If this is a "/car" that you are sellin... Oct 9 2019, 11:54 AM
flat4guy Beautiful car - it's always a timing issue wit... Oct 9 2019, 08:37 PM
Dominic More pics.. last one shows the rear trunk panel wi... Oct 13 2019, 04:22 PM
sixnotfour I bought it out of a Barn 1998?? 2011 BAT
https://... Oct 29 2019, 11:45 AM
RSWannabe I just had this ad brought to my attention. I... Nov 8 2019, 01:48 PM
Dominic
I just had this ad brought to my attention. I... Nov 8 2019, 07:44 PM
Dominic Update: 11/12/2019 Lowered price to $75,000. Nov 12 2019, 08:44 PM
ben*james Deposit made Nov 26 2019, 08:38 PM
sixnotfour
Deposit made
congrats..it was close to going to ... Dec 5 2019, 10:16 AM
Cairo94507 Congratulations to Ben and Dominic. :beer2: Nov 27 2019, 02:13 PM
ben*james
Th... Dec 7 2019, 05:29 PM
Dominic
T... Dec 7 2019, 07:55 PM
flat4guy Congratulations - I am jealous of the new owners. Nov 27 2019, 09:20 PM
914Love This is my friends 914 out of Seattle... Dec 5 2019, 04:56 AM
Cairo94507 You are welcome and my pleasure Dominic-- you have... Dec 8 2019, 08:42 AM
ben*james I've not stopped smiling since seeing and driv... Dec 9 2019, 12:14 PM
porbmw DAMN!
NICE car!
Congrats! Dec 9 2019, 01:08 PM
71six What ever became of this wonderful car? May 14 2022, 04:39 PM
eric9144
@ben*ja... May 14 2022, 10:44 PM
porsha916 hi, Is the vin: 9140430420, A 914/6 I owned from 1... May 15 2022, 08:45 PM
71six
hi, Is the vin: 9140430420, A 914/6 I owned from ... May 16 2022, 03:35 PM
Doug914 This is now on BAT . I think the selling dealer is... Jan 10 2025, 09:02 PM
Dominic Car looks great. It looks like Ben put a bunch of ... Jan 11 2025, 01:40 PM
Doug914 It does look great. But I’m struggling to see ho... Jan 12 2025, 04:40 AM
sixnotfour
It does look great. But I’m struggling to see h... Jan 16 2025, 03:01 PM
Doug914
It does look great. But I’m struggling to see ... Jan 30 2025, 12:04 PM
Ron914 It sold over the weekend after a RNM bid of ... Jan 20 2025, 02:55 PM
eric9144
It sold over the weekend after a RNM bid of ... Jan 20 2025, 05:17 PM
Ron914 This is why someday when I buy my next 914 I will ... Jan 30 2025, 08:07 PM
Ron914
:agree:
Here's an exa... Jan 31 2025, 09:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 12:55 PM |
