| JeffBowlsby |
Oct 15 2025, 10:03 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,368 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
In another post it was said. ‘Wife bought a new Bronco in 2022. We sold it a few months ago and bought a 1972 Bronco to replace it.’
Been pondering the same dilemma. Not talking about sports cars in this thread. New cars are expensive to buy, maintain, repair and insure. Loaded with tech, and numerous features they can be very complicated. Even lower cost new cars can fit this description. A recent article says new cars average $50K now, even an F150 pickup is reportedly $65K. The new cars we really want can be over six figures. New cars depreciate like rocks whereas vintage car values are much more stable. I’m thinking fully restored cars that would pass a thorough PPI. No project cars. No complicated cars. No “they only made X of these” with an inflated cost. No 40 Ford restorods or Model As. Nothing particularly ostentatious. I think the possibilities, risks, rewards of a good quality vintage car instead of new could be advantageous. We need to consider at least reliability, availability of shops that can provide service, parts availability. Certainly reasonable safety is important which most older cars are not well equipped. Collector insurance may help reduce costs if that fits the situation. Which specific vehicles would you consider as good candidates for a family car be it a sedan, SUV or minivan? Both domestic and imports, low mileage, well cared for. Condition is more important than collectibility. Probably A/C is a must but could be retrofitted. Want to focus on vehicles that would be reliable as daily drivers. I am thinking of 60s-70s Chevys, Fords, 2000s Hondas and Toyotas. 1975 and earlier would be beneficial to those of us in CA. Valued at something less than $50K. What are your ideas? |
| DennisV |
Oct 17 2025, 04:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,040 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
In another post it was said. ‘Wife bought a new Bronco in 2022. We sold it a few months ago and bought a 1972 Bronco to replace it.’ Been pondering the same dilemma. Not talking about sports cars in this thread. Which specific vehicles would you consider as good candidates for a family car be it a sedan, SUV or minivan? Both domestic and imports, low mileage, well cared for. Condition is more important than collectibility. Probably A/C is a must but could be retrofitted. Want to focus on vehicles that would be reliable as daily drivers. I am thinking of 60s-70s Chevys, Fords, 2000s Hondas and Toyotas. 1975 and earlier would be beneficial to those of us in CA. Valued at something less than $50K. What are your ideas? This is a super interesting thread. Like @Jack_Standz we have owned a Cayenne (2014) for several years. It is a very versatile, comfortable, and enjoyable to drive. It continues to be reliable enough for every day and on long trips without worry. Part of the analysis needs to be how much you're willing to spend on maintenance and / or are you expecting to be able to do maintenance yourself. In Northern California at an independent repair shop the intermediate maintenance on my 2014 911 runs about $650. No repairs needed. I enjoy wrenching, but am very reluctant to work on late 90s and new cars. Once computer-dependent diagnostics came onto the scene with ODB-II and CAN bus I gave up doing much. Though I did do a factory trailer hitch install on our Cayenne. I saw too many times on my 1997 Boxster where a competent independent shop with a Porsche diagnostic scanner still had to rely on their dealer contacts to help decipher codes and get to root cause on issues. |
| Superhawk996 |
Oct 17 2025, 10:09 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,144 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I enjoy wrenching, but am very reluctant to work on late 90s and new cars. Once computer-dependent diagnostics came onto the scene with ODB-II and CAN bus I gave up doing much. Why? OBDII makes things easier. In the majority of cases the codes point you to what the problem is. Swap a sensor, and you’re back in business. Sure there are weird situations that require a brain to get to root cause but those are usually the exception rather than the rule. Unfortunately this has lead to many “technicians” becoming nothing more than glorified parts swappers. Having a good scan tool that is compatible with the OEM specific codes is key. For example on the BMW X5 my generic scan tool can’t reset or give much insight on some of BMWs specific / unique codes. For example: had a fault for transfer case oil abrasion (i.e. oil worn out). My generic scan tool can’t reset it. Once I got an appropriate version of BMWs ISTA diagnostics working (a whole fiasco unto itself!!) - I was able to change the oil, reset the adaptions, and clear the code - problem solved. |
| DennisV |
Oct 18 2025, 06:36 AM
Why? OBDII makes things easier. In the majority of cases the codes point you to what the problem is. Swap a sensor, and you’re back in business. Having a good scan tool that is compatible with the OEM specific codes is key. For example on the BMW X5 my generic scan tool can’t reset or give much insight on some of BMWs specific / unique codes. I used to take my '97 Boxster to a competent independent repair shop that only worked on Porsche. They had a genuine Porsche diagnostic tool. On more than one occasion, they couldn't get enough info from the tool to get to root cause. Luckily they had contacts at the dealer who sometimes had to escalate to the factory to come up with a fix. I was also under the impression that OEM scanners were thousands of dollars and required software subscriptions. Maybe things have changed and the scanners are better and cheaper now. (IMG:style_emoticons/default/confused24.gif) |
| Superhawk996 |
Oct 18 2025, 07:42 AM
I used to take my '97 Boxster to a competent independent repair shop that only worked on Porsche. They had a genuine Porsche diagnostic tool. On more than one occasion, they couldn't get enough info from the tool to get to root cause. Luckily they had contacts at the dealer who sometimes had to escalate to the factory to come up with a fix. I was also under the impression that OEM scanners were thousands of dollars and required software subscriptions. Maybe things have changed and the scanners are better and cheaper now. (IMG:style_emoticons/default/confused24.gif) Not sure what’s going on at your Indy. Are we taking about engine emissions codes or other stuff like body controls (windows, locks, control of the convertible top, instruments, etc?) Keep in mind that OBDII came into effect in 1996. In a lot of ways it was still immature in 97’ and OEMs were still trying to figure it out themselves. As a counter point, I’ve never had any OBDII issues with my 98’ Camry. Here’s the reality, OBD originated as engine / emissions control. Engine OBDII is standardized by regulation and most of the engine codes and failure modes are dictated by regulation and well mapped between this failure = this root cause. When you get to OEM codes for all other systems (body, chassis, electrical) it’s up to the OEM to define codes and what sets them. In my example - a BMW transfer case oil abrasion code isn’t dictated by regulation and BMW defines the code, what sets it, and what it takes to repair and clear the code. With respect to scan tools, this is a topic worthy of its own thread but few here would care because it’s OT to 914’s. I didn’t mean to imply the scan tool has to be OEM. Yes, many of those can be expensive and do require OEM subscriptions. However some OEMs allow short term subscription (by day, week, or month) but are still somewhat pricy. BMW for example is $32/day, $270 /month and $2500 /year as I recall. What was referring to is there are two basic classes of aftermarket scan tools: 1) Cheap (ie less than $100 ish) that read only the standardized, regulated OBDII engine codes. These tools do a poor job of being able to read or properly identify the OEM enhanced codes. These tools are usually incapable of being able to read out live data from the vehicle or to do bidirectional communication with the vehicle to activate systems or test sensors. Example Innova’s low end tools. These aren’t bad tools - just limited in what they can do. 2) Scan tools that are still generic and can read many OEMs but capable of bi-directional communication. They can read live data. They can control actuators. They can perform OEM specific service resets. These have a huge price range between a couple hundred dollars and thousands. Some brands of scan tools handle certain OEMs better than others. Examples: Foxwell, Autel, Thinktool, etc. But the bottom line is OBD isn’t something to be afraid of. If you can tune a carb, you can figure out how to use OBDII scan tools (even a cheap one) to your advantage. |
JeffBowlsby New car vs. Restored classic? Oct 15 2025, 10:03 PM
fiacra I have to say I have been loving the 1983 Volvo 24... Oct 15 2025, 10:34 PM
wonkipop one word - toyota.
one decade - 90s.
its called a... Oct 16 2025, 02:26 AM
Superhawk996
one word - toyota.
one decade - 90s.
:agree:
... Oct 16 2025, 06:58 AM
wonkipop
one word - toyota.
one decade - 90s.
:agree: ... Oct 16 2025, 03:22 PM
Dave_Darling 90s Honda Civics. You probably remember my CRX--t... Oct 16 2025, 02:50 AM
Jack Standz Arguably better than a bronco.
Porsche 955 (or 95... Oct 16 2025, 04:20 AM
Porsche 955 (or 9... Oct 16 2025, 06:05 AM
mepstein Classic car insurance only really works if you hav... Oct 16 2025, 04:38 AM
JeffBowlsby
Classic car insurance only really works if you ha... Oct 16 2025, 10:32 AM
emerygt350 When I was looking for my mustang I was considerin... Oct 16 2025, 05:21 AM
Lockwodo
When I was looking for my mustang I was consideri... Oct 16 2025, 10:03 AM
GregAmy There are a lot of advantages to older cars, some ... Oct 16 2025, 06:12 AM
flipb I've been daydreaming lately about maybe getti... Oct 16 2025, 06:44 AM
Jack Standz
I also have a 1992 968. This is more of a modern ... Oct 16 2025, 07:01 AM
carr914 all of my cars are Old ( kinda like me :D )
I da... Oct 16 2025, 07:06 AM
Optimusglen Taking Classic to be 30 years old or older, the 90... Oct 16 2025, 07:44 AM
brant I have 5 cars and many motorcycles
The newest is... Oct 16 2025, 08:10 AM
Superhawk996
Maintenance is my specialty and they all need i... Oct 16 2025, 08:38 AM
Steve I also love Toyotas. We have a 2002 sequoia with ... Oct 16 2025, 08:14 AM
Root_Werks Don't use Collector car insurance or Collector... Oct 16 2025, 11:13 AM
Superhawk996
It's hard to think a 2025 mainstream vehicle ... Oct 16 2025, 11:30 AM
gereed75 I am also an older car guy. Just picked up a low m... Oct 16 2025, 01:34 PM
Cfletch I daily a 1982 W123 Wagon, its super easy to work ... Oct 16 2025, 01:57 PM
brant This thread got me to thinking about my junk
10 a... Oct 16 2025, 02:02 PM
Root_Werks
10 ... Oct 16 2025, 02:18 PM
930cabman
10 ... Oct 16 2025, 02:34 PM
Root_Werks
10... Oct 16 2025, 02:51 PM
brant All but one
The 71’ bmw R75 has its motor in Aus... Oct 16 2025, 02:48 PM
chmillman My 'daily driver' is a 2006 Honda FRV - ne... Oct 16 2025, 03:11 PM
bkrantz I don't know.
I think our biases are showing,... Oct 16 2025, 09:37 PM
wonkipop
I don't know.
I think our biases are showing... Oct 17 2025, 05:08 AM
Superhawk996
I don't know.
I think our biases are showing... Oct 17 2025, 09:46 AM
bkrantz
I don't know.
I think our biases are showin... Oct 17 2025, 07:53 PM
Superhawk996
IMO basic comfort (not entertainment or distrac... Oct 17 2025, 08:21 PM
930cabman My DD has been an F150 for a few decades, I purcha... Oct 17 2025, 05:00 AM
Front yard mechanic I have a simple method at least one car from every... Oct 17 2025, 06:07 AM
mepstein I'll drive most anything. My wife won't. S... Oct 17 2025, 06:25 AM
Superhawk996
I'll drive most anything. My wife won't. ... Oct 17 2025, 09:55 AM
rjames In my family I've seen Toyotas and Hondas run ... Oct 17 2025, 10:15 AM
Root_Werks
My wife bought her first ever new car last year.... Oct 17 2025, 12:07 PM
Literati914 Those powered mirrors that close when you hit lock... Oct 17 2025, 12:04 PM
Lockwodo Old cars have personality and are more fun to driv... Oct 17 2025, 12:09 PM
peteinjp Funny to me to think of a car from 2000 on as old.... Oct 17 2025, 07:02 PM
Montreal914 I miss daily driving my 73 914. :driving: Oct 17 2025, 10:49 PM
infraredcalvin I’m surprised nobody has mentioned E30 BMW, i ha... Oct 18 2025, 01:43 AM
JeffBowlsby We are in a paradigm shift. Broadly speaking,
Bo... Oct 18 2025, 08:30 AM
Superhawk996
... Oct 18 2025, 10:50 AM
wonkipop
B... Oct 19 2025, 12:44 AM
chmillman
M... Oct 19 2025, 02:51 AM
bkrantz
B... Oct 19 2025, 08:01 PM
VaccaRabite
Later generations tend not to share those perspe... Oct 20 2025, 07:54 PM
didenpx I had a 2020 base GTI with 6-speed and still very ... Oct 18 2025, 09:33 AM
Jett Bought this fellow off BAT a couple of weeks agoâ€... Oct 19 2025, 09:58 AM
didenpx
Bought this fellow off BAT a couple of weeks agoâ... Oct 19 2025, 11:08 AM
campbellcj 100-Series Land Cruiser or Lexus LX470 is one of t... Oct 19 2025, 10:52 AM
Chris914n6 90s are kinda the sweet spot. Multi-port FI on a b... Oct 19 2025, 11:22 PM
flipb Probably nobody in this thread wants to hear this,... Oct 20 2025, 09:32 AM
didenpx I believe I recently read in Wall Street Journal t... Oct 20 2025, 09:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 03:38 AM |
