| Mueller |
Feb 3 2005, 07:27 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
okay...for a factory 914 /4, the front calipers (piston area wise) are 1.61 larger than the rear....(42mm and 33mm)
for early 911's (up to '84), the fronts are 1.6 larger from '84 to '89, the fronts are only 1.3 times larger than the rears....then the ratios vary from 1.4 to 1.7 until the arrival of the 1st Twin-turbo, that car has calipers that have piston areas 2X the size of the rears !!!!! I'm just wondering what combo people have successfully ran.....it's interesting to note that the standard Boxster front calipers if bolted to the front of a 911, the Boxster piston area is only 1.05 larger than the standard 911 fronts.....seems like a darn near equal swap, except for the bigger pads you get with the Boxster calipers (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| fiid |
Feb 16 2005, 12:13 PM
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,828 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) I think you hit the nail on the head.
Pad area would effect wear rate, and I bet it has some thermal effects too - like felxing you mentioned. If you assume that the braking force originates (on average) from the center of the pad, then a bigger pad and larger radius rotor whould also move the braking force further out, giving it a greater mechanical advantage (of course - larger tire radius would lose you this battle from the other end).... |
Mueller Poll: Brake upgrades..what kind of ratio? Feb 3 2005, 07:27 PM
bd1308 um...stock? I'm gonna wait till my rears rust ... Feb 3 2005, 07:28 PM
SirAndy Feb 3 2005, 07:58 PM
d914 944 turbo front
carrera rears Feb 3 2005, 08:02 PM
Mueller Feb 3 2005, 08:04 PM
SirAndy Feb 3 2005, 08:12 PM
Eric_Shea S-Caliper
M-Caliper
T-Fitting
I just went off the... Feb 16 2005, 09:58 AM
JmuRiz Front - 4 piston Brembo monoblocks
Rear - Stock wi... Feb 16 2005, 10:19 AM
bondo I have the second option, but I can't tell you... Feb 16 2005, 10:25 AM
don9146 I have 964 front calipers clamping cross-drilled a... Feb 16 2005, 11:00 AM
fiid Friction is a function of normal force, not of sur... Feb 16 2005, 11:25 AM
ArtechnikA 'S' calipers front, widened 914.6 calipers... Feb 16 2005, 11:29 AM
v82go Front= M (911)
Rear=stock (redrilled/5lug)
Prop. v... Feb 16 2005, 11:36 AM
bondo Feb 16 2005, 11:51 AM
fiid felxing is the combination of felching and flexing... Feb 16 2005, 12:14 PM
anthony Feb 16 2005, 12:17 PM
1973914 Boxster Monoblocks up front/Vented rotors
Carrera ... Feb 16 2005, 12:23 PM
bondo Feb 16 2005, 12:44 PM
ArtechnikA <... Feb 16 2005, 12:59 PM
fiid Feb 16 2005, 01:06 PM
lapuwali Feb 16 2005, 01:28 PM
Andy Feb 16 2005, 02:11 PM
lapuwali Feb 16 2005, 03:20 PM
fiid thanks! I was wondering about the tire case. Feb 16 2005, 03:23 PM
lapuwali Feb 16 2005, 05:05 PM
Mueller speaking of pads....from what I have read, if you ... Feb 16 2005, 05:32 PM
Andyrew I kinda want to put 944 turbo calipers on, then 91... Feb 16 2005, 05:35 PM
Mueller <... Feb 16 2005, 05:39 PM
Mueller are you sure the calipers are the same? I know the... Feb 16 2005, 05:41 PM
lapuwali <... Feb 16 2005, 05:59 PM
Andyrew Dad doesnt think theres any difference in the fron... Feb 16 2005, 06:36 PM
bondo ... Feb 16 2005, 07:00 PM
fiid ... Feb 16 2005, 07:40 PM
xitspd Mike,
I am using a 993 Twin Turbo front on my Tee... Feb 16 2005, 10:04 PM
xitspd Feb 16 2005, 10:05 PM
Mueller Feb 17 2005, 12:25 AM
neo914-6 Bill ran this on his track car, now Neo914...
911... Feb 17 2005, 02:00 AM
seanery my upgraded car has 951 calipers front boxster cal... Feb 17 2005, 02:08 AM
seanery here's the scoop on the 951 calipers front vs ... Feb 17 2005, 02:12 AM
TimT Front: Wilwood billet superlites w 11.75x1.25 disc... Feb 17 2005, 08:01 AM
CptTripps Mine came with the BMWs on the front, stock rears,... Feb 17 2005, 10:02 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:54 PM |
