> Poll: Brake upgrades..what kind of ratio?, F=big/R= big or F=big/R=little or ???
What combination of upgraded calipers do you have?
"standard" BMW front with stock rears? (31% differance) [ 7 ] ** [25.93%]
2-piston 911 F and stock /4 R?(31% diff.) [ 8 ] ** [29.63%]
2-piston 911 F and 911 R?(small 38mm M caliper)(37%) [ 3 ] ** [11.11%]
2-piston 911 F and 911 R?(med. 42mm M caliper)(23%) [ 6 ] ** [22.22%]
2-piston 911 F and 911 F?(large 48mm M caliper)(0%) [ 3 ] ** [11.11%]
Total Votes: 27
Guests cannot vote
Mueller
post Feb 3 2005, 07:27 PM
914 Freak!
okay...for a factory 914 /4, the front calipers (piston area wise) are 1.61 larger than the rear....(42mm and 33mm)
for early 911's (up to '84), the fronts are 1.6 larger
from '84 to '89, the fronts are only 1.3 times larger than the rears....then the ratios vary from 1.4 to 1.7 until the arrival of the 1st Twin-turbo, that car has calipers that have piston areas 2X the size of the rears !!!!!
I'm just wondering what combo people have successfully ran.....it's interesting to note that the standard Boxster front calipers if bolted to the front of a 911, the Boxster piston area is only 1.05 larger than the standard 911 fronts.....seems like a darn near equal swap, except for the bigger pads you get with the Boxster calipers (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mueller
post Feb 17 2005, 12:25 AM
914 Freak!
QUOTE (xitspd @ Feb 16 2005, 09:04 PM)
Mike,
I am using a 993 Twin Turbo front on my Teeners front
nice.... (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
according to a chart I've read....the piston area of your front calipers are 2X larger than the rears (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ...they have the most amount of front bias than any other P-car (production)..... 2:1
love your car (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
Mueller   Poll: Brake upgrades..what kind of ratio?   Feb 3 2005, 07:27 PM
bd1308   um...stock? I'm gonna wait till my rears rust ...   Feb 3 2005, 07:28 PM
SirAndy     Feb 3 2005, 07:58 PM
d914   944 turbo front carrera rears   Feb 3 2005, 08:02 PM
Mueller     Feb 3 2005, 08:04 PM
SirAndy     Feb 3 2005, 08:12 PM
Eric_Shea   S-Caliper M-Caliper T-Fitting I just went off the...   Feb 16 2005, 09:58 AM
JmuRiz   Front - 4 piston Brembo monoblocks Rear - Stock wi...   Feb 16 2005, 10:19 AM
bondo   I have the second option, but I can't tell you...   Feb 16 2005, 10:25 AM
don9146   I have 964 front calipers clamping cross-drilled a...   Feb 16 2005, 11:00 AM
fiid   Friction is a function of normal force, not of sur...   Feb 16 2005, 11:25 AM
ArtechnikA   'S' calipers front, widened 914.6 calipers...   Feb 16 2005, 11:29 AM
v82go   Front= M (911) Rear=stock (redrilled/5lug) Prop. v...   Feb 16 2005, 11:36 AM
bondo     Feb 16 2005, 11:51 AM
fiid   http://www.914world.com/bbs2/h...   Feb 16 2005, 12:13 PM
fiid   felxing is the combination of felching and flexing...   Feb 16 2005, 12:14 PM
anthony     Feb 16 2005, 12:17 PM
1973914   Boxster Monoblocks up front/Vented rotors Carrera ...   Feb 16 2005, 12:23 PM
bondo     Feb 16 2005, 12:44 PM
ArtechnikA   <...   Feb 16 2005, 12:59 PM
fiid     Feb 16 2005, 01:06 PM
lapuwali     Feb 16 2005, 01:28 PM
Andy     Feb 16 2005, 02:11 PM
lapuwali     Feb 16 2005, 03:20 PM
fiid   thanks! I was wondering about the tire case.   Feb 16 2005, 03:23 PM
lapuwali     Feb 16 2005, 05:05 PM
Mueller   speaking of pads....from what I have read, if you ...   Feb 16 2005, 05:32 PM
Andyrew   I kinda want to put 944 turbo calipers on, then 91...   Feb 16 2005, 05:35 PM
Mueller   <...   Feb 16 2005, 05:39 PM
Mueller   are you sure the calipers are the same? I know the...   Feb 16 2005, 05:41 PM
lapuwali   <...   Feb 16 2005, 05:59 PM
Andyrew   Dad doesnt think theres any difference in the fron...   Feb 16 2005, 06:36 PM
bondo   ...   Feb 16 2005, 07:00 PM
fiid   ...   Feb 16 2005, 07:40 PM
xitspd   Mike, I am using a 993 Twin Turbo front on my Tee...   Feb 16 2005, 10:04 PM
xitspd     Feb 16 2005, 10:05 PM
Mueller     Feb 17 2005, 12:25 AM
neo914-6   Bill ran this on his track car, now Neo914... 911...   Feb 17 2005, 02:00 AM
seanery   my upgraded car has 951 calipers front boxster cal...   Feb 17 2005, 02:08 AM
seanery   here's the scoop on the 951 calipers front vs ...   Feb 17 2005, 02:12 AM
TimT   Front: Wilwood billet superlites w 11.75x1.25 disc...   Feb 17 2005, 08:01 AM
CptTripps   Mine came with the BMWs on the front, stock rears,...   Feb 17 2005, 10:02 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:26 PM
