| Mueller |
Feb 17 2005, 04:05 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Looking for local early (3" caliper spacing)
I placed an order with Wilwood today for a pair of their 12.19" diameter vented rotors along with the aluminum mounting hats..... The factory 911 rotors are one piece, with the rotor and the hat cast as one piece. The reason I went with the 12 inch rotor was to make it easier to bolt on the 4-pot rx-7 calipers....another 914 owner here welded on new caliper brackets, but I didn't want to go that route (I might weld new brackets for the trailing arm, but I didn't want to play around too much with the front struts) I'm hoping these new rotors will fit a 911 strut and allow the same rx-7 calipers to be used..... local people only, I don't want to deal with shipping (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) This post has been edited by Mueller: Feb 17 2005, 05:23 PM Attached image(s)
| fiid |
Feb 17 2005, 09:51 PM
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,828 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
WTF? You think you can post something like that without an explanation..? Did you photoshop that? |
Mueller 911 struts to borrow?? Need to test fit parts .... Feb 17 2005, 04:05 PM
Aaron Cox do these use the super cool billet hubs? Feb 17 2005, 04:07 PM
Mueller <... Feb 17 2005, 05:01 PM
andys Check with Desert Hybrids. They did a car with 4x ... Feb 17 2005, 05:13 PM
Jeroen Mike, how thich are those rotors? Feb 17 2005, 05:14 PM
neo914-6 It's not going together anytime soon[QUOTE]
Ho... Feb 17 2005, 05:18 PM
fiid I have 3.5" spacing - you are welcome to come over... Feb 17 2005, 05:19 PM
Mueller Feb 17 2005, 05:20 PM
Mueller Feb 17 2005, 05:23 PM
chunger Hey Neo914 http://www.914world.... Feb 17 2005, 05:32 PM
TimT Mike you will have to make some spacers, and space... Feb 17 2005, 05:48 PM
Mueller Feb 17 2005, 06:03 PM
TimT its no biggie, but you will need a spacer. I have ... Feb 17 2005, 06:11 PM
Mueller Feb 17 2005, 06:16 PM
chunger betcha could make it clear the A-arm if you scallo... Feb 17 2005, 06:59 PM
ppickerell Mike,
I have a 911 front end assembly from a late ... Feb 17 2005, 09:11 PM
Aaron Cox Feb 17 2005, 11:32 PM
Mueller Feb 18 2005, 12:34 AM
Jeroen Tim, what's the deal with the 944turbo rotors ... Feb 18 2005, 05:58 AM
TimT Jeroen, I have this brake set up on my 911. With ... Feb 18 2005, 07:06 AM
914Timo ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:29 AM |
