> 911 struts to borrow?? Need to test fit parts ...., 12.19" Wilwood rotors w/alum hat...
Mueller
post Feb 17 2005, 04:05 PM
914 Freak!
Looking for local early (3" caliper spacing)
I placed an order with Wilwood today for a pair of their 12.19" diameter vented rotors along with the aluminum mounting hats.....
The factory 911 rotors are one piece, with the rotor and the hat cast as one piece.
The reason I went with the 12 inch rotor was to make it easier to bolt on the 4-pot rx-7 calipers....another 914 owner here welded on new caliper brackets, but I didn't want to go that route (I might weld new brackets for the trailing arm, but I didn't want to play around too much with the front struts)
I'm hoping these new rotors will fit a 911 strut and allow the same rx-7 calipers to be used.....
local people only, I don't want to deal with shipping (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
This post has been edited by Mueller: Feb 17 2005, 05:23 PM
Mueller
post Feb 18 2005, 12:34 AM
914 Freak!
QUOTE (fiid @ Feb 17 2005, 08:51 PM)
QUOTE (Mueller @ Feb 17 2005, 04:16 PM)
have you known anyone to run the "scalloped" rotors??
WTF? You think you can post something like that without an explanation..? Did you photoshop that?
you've never seen these??
scalloped rotor, 12.19 dia X .81 thick, only 5.9 pounds (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mueller   911 struts to borrow?? Need to test fit parts ....   Feb 17 2005, 04:05 PM
Aaron Cox   do these use the super cool billet hubs?   Feb 17 2005, 04:07 PM
Mueller   <...   Feb 17 2005, 05:01 PM
andys   Check with Desert Hybrids. They did a car with 4x ...   Feb 17 2005, 05:13 PM
Jeroen   Mike, how thich are those rotors?   Feb 17 2005, 05:14 PM
neo914-6   It's not going together anytime soon[QUOTE] Ho...   Feb 17 2005, 05:18 PM
fiid   I have 3.5" spacing - you are welcome to come over...   Feb 17 2005, 05:19 PM
Mueller     Feb 17 2005, 05:20 PM
Mueller     Feb 17 2005, 05:23 PM
chunger   Hey Neo914 http://www.914world....   Feb 17 2005, 05:32 PM
TimT   Mike you will have to make some spacers, and space...   Feb 17 2005, 05:48 PM
Mueller     Feb 17 2005, 06:03 PM
TimT   its no biggie, but you will need a spacer. I have ...   Feb 17 2005, 06:11 PM
Mueller     Feb 17 2005, 06:16 PM
chunger   betcha could make it clear the A-arm if you scallo...   Feb 17 2005, 06:59 PM
ppickerell   Mike, I have a 911 front end assembly from a late ...   Feb 17 2005, 09:11 PM
fiid   <...   Feb 17 2005, 09:51 PM
Aaron Cox     Feb 17 2005, 11:32 PM
Mueller     Feb 18 2005, 12:34 AM
Jeroen   Tim, what's the deal with the 944turbo rotors ...   Feb 18 2005, 05:58 AM
TimT   Jeroen, I have this brake set up on my 911. With ...   Feb 18 2005, 07:06 AM
914Timo     Feb 18 2005, 08:55 AM
914Timo
  Feb 18 2005, 08:59 AM
fiid   <...   Feb 18 2005, 11:04 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:30 PM
