> I am thinking about being rash!
Bleyseng
post Feb 26 2005, 08:36 PM
Aircooled Baby!
Picked up a 2.4l six today and maybe this one has found a home if I scrap all my big 2.4L four plans.
I can't decide:
Big screaming four
or
2.4lsix
or wait to save up some more money and install a 3.2!
What do you think I should do??
Geoff
ArtechnikA
post Feb 27 2005, 09:07 AM
rich herzog
QUOTE (Bleyseng @ Feb 26 2005, 11:29 PM)
supposed to have RSR cams in it already
Factory carbs
okay - -something- is wrong with this picture...
(or you've found out why it runs like crap and was available to you cheap...)
a 72-73 2,4 911T engine should probably have come with Zeniths but a Weber change is not uncommon. it does, however, have 7,5:1 compression and the RSR Sprint Cam is a pretty radical profile - i'm surprised there's enough static compression with that much overlap to even get the fire lit.
unless it also has big compression pistons, but then you have to wonder if it has had all the other updates necessary to actually use that level of performance (big ports, big valves, uprated valve springs for the rev range where those cams work...
RSR sprint cams work great with 3,0 liters and 10.3:1 compression.
be interesting to find out what you've got there, really !
the type number is a start - i'm guessing 911/57
Bleyseng   I am thinking about being rash!   Feb 26 2005, 08:36 PM
ClayPerrine   Go for the six.... But make sure that you don...   Feb 26 2005, 08:40 PM
xsboost90   a six would -in theory- just add to the value of y...   Feb 26 2005, 08:42 PM
Jeroen   go six!   Feb 26 2005, 08:44 PM
TimT   You can break down that 2.4 and rebuild it into a ...   Feb 26 2005, 08:48 PM
ArtechnikA     Feb 26 2005, 09:46 PM
J P Stein   Got a type number on that, Geoff? The shroud color...   Feb 26 2005, 09:53 PM
ClayPerrine   If the webers are factory, it's a T motor. All...   Feb 26 2005, 09:54 PM
Bleyseng   supposed to have RSR cams in it already Factory ca...   Feb 26 2005, 10:29 PM
red914   find a roller and have both! c'mon, like ...   Feb 26 2005, 10:37 PM
anthony   Go for the big 4. Don't you already have the N...   Feb 26 2005, 10:46 PM
redshift   I'd put the 2.4/6 in there... but not that one...   Feb 26 2005, 10:52 PM
VegasRacer   six   Feb 26 2005, 10:53 PM
Brando   if the 6 is going to be opened up... best to put s...   Feb 26 2005, 10:57 PM
boxstr   Geoff put that six in your westy. And then get a V...   Feb 26 2005, 11:21 PM
J P Stein   The type # is just below the hose clamp in your pi...   Feb 27 2005, 01:06 AM
trekkor     Feb 27 2005, 01:22 AM
MecGen   Hi I, like most teeners, have thought about conver...   Feb 27 2005, 06:41 AM
scotty b   My .02 Put the six in your driver with 67S cams, o...   Feb 27 2005, 08:30 AM
redshift   Uhh... that is an upside down 9. M   Feb 27 2005, 08:43 AM
ArtechnikA   ...   Feb 27 2005, 09:07 AM
9146986   http://www.914world.com/bbs2/h...   Feb 27 2005, 09:33 AM
Mark Henry   Build the four...you already have the nickies. O...   Feb 27 2005, 09:44 AM
Bleyseng   engine numbers   Feb 27 2005, 12:41 PM
Bleyseng   serial#   Feb 27 2005, 12:42 PM
Bleyseng   carbs   Feb 27 2005, 12:42 PM
Aaron Cox   uhmm zeniths..... http://www.9...   Feb 27 2005, 12:43 PM
Bleyseng   new owner!   Feb 27 2005, 12:43 PM
Bleyseng   Guess this means I am gonna try to build a screami...   Feb 27 2005, 12:49 PM
pete-stevers   six,[size=14]six [img]http://...   Feb 27 2005, 12:55 PM
Mark Henry   [size=7]DWD at it's finest [img...   Feb 27 2005, 12:57 PM
Aaron Cox   ...   Feb 27 2005, 12:58 PM
Bleyseng   http://www.914world.com/bbs2/h...   Feb 27 2005, 02:16 PM
Eddie914   SixnotFour, You don't happen to have a 3.2/6 ...   Feb 27 2005, 09:30 PM
Sparky   I had a rash once, the doctor gave me some lotion ...   Feb 27 2005, 11:24 PM
!   Has ANYONE ever met Dirk Wright?   Feb 27 2005, 11:26 PM
Bleyseng   That I recall he was in the Mid West somewhere. H...   Feb 28 2005, 09:15 AM
!   ...   Feb 28 2005, 09:22 AM
Cap'n Krusty   ...   Feb 28 2005, 09:24 AM
mike_the_man   Geoff, You gonna sell that six? How much do you ...   Feb 28 2005, 09:54 AM
Bleyseng   Its gone! Sold it. Geoff   Feb 28 2005, 10:53 AM
mike_the_man   Well that was quick. Crap! ...   Feb 28 2005, 01:27 PM
GTeener   http://www.914world.com/bbs2/html/e...   Feb 28 2005, 01:31 PM
Bleyseng   ok, wise guys. Where in the pics is the 911/57 or ...   Feb 28 2005, 01:40 PM
!   Just above the serial number....it's usually v...   Feb 28 2005, 01:42 PM
Bleyseng   So faint thats its not freakin there!   Feb 28 2005, 01:54 PM
sixnotfour   6- six cyl. 5- TV Zenith Carbs 1- USA mech inj. 3...   Feb 28 2005, 02:04 PM
Bleyseng   Hallejuah! someone who can read serial numbers...   Feb 28 2005, 02:08 PM
J P Stein   Below and to the right of the S/N. there's a r...   Feb 28 2005, 02:09 PM
sixnotfour   5R Dan looked. Now he hopes it runs Good Enough <...   Feb 28 2005, 02:13 PM
J P Stein   Right on that boss under the oil fitting, IIRC. I ...   Feb 28 2005, 02:19 PM
sixnotfour   Actually it is straight back from the temp sender ...   Feb 28 2005, 02:34 PM
ArtechnikA   <...   Feb 28 2005, 02:46 PM
Root_Werks
  Feb 28 2005, 03:06 PM
Root_Werks     Feb 28 2005, 05:00 PM
J P Stein   It's like any other reference book, you don...   Feb 28 2005, 06:46 PM
- Lo-Fi Version Time is now: 6th June 2024 - 07:32 PM
