Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
How critical is the draining of the oil from the turbo back to the engine?
For the turbo that is not going to be installed on my car, 'cause you cannot turbo a 914, I'm toying with mounting the turbo either right behind the collector on my header (see second picture...red outline on header, mine is similar to the one in picture....) (a la' Chapman's 3.0 turbo setup with turbo in the back) or use a mandrel bent U bend pipe to locate the turbo up where Ben M (airsix) has his turbo located (IMG:http://www.914world.com/bbs2/uploads/post-2-1095059341.jpg) Since the oil going to the turbo is pressurized, shouldn't the oil have no problems getting out of the bearings of the turbo and back to the motor without assistance?? Attached image(s) ![]() |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
If I remember correctly our 1987 930 has a drain from the turbo that goes to a small catch can and then back to the sump? I'll take a look to be sure but I remember the lines are all stainless steel since the turbo gets pretty hot when you have your foot in it!
Lo-Fi Version | Time is now: 13th June 2024 - 07:04 AM |
