Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Sure, this is a re-run.
I ran the track and got brake fade 3/4 of way into each session. I just want to upgrade the pads and fluid right now. What do you recommend/are using. Wear is not a factor. I want the best stopping power for the stock FOUR calipers/rotors. Do I need to replace the M/C with a bigger unit and what are your feelings on the prop valve vs "tee" arguement. Also considering the SS brake lines. Thanks and thanks to Mark for helping with the brake bleeding on track day. KT Attached image(s) ![]() |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
I have to agree with Eric, change to larger brakes and change out your fluid and M/C. A fast car is only as good as it's brakes.
Lo-Fi Version | Time is now: 11th July 2025 - 07:25 AM |
