> Brakes, tell me something
Trekkor
post May 2 2005, 09:26 PM
I do things...
Sure, this is a re-run.
I ran the track and got brake fade 3/4 of way into each session.
I just want to upgrade the pads and fluid right now.
What do you recommend/are using.
Wear is not a factor. I want the best stopping power for the stock FOUR calipers/rotors.
Do I need to replace the M/C with a bigger unit and what are your feelings on the prop valve vs "tee" arguement.
Also considering the SS brake lines.
Thanks and thanks to Mark for helping with the brake bleeding on track day.
KT
Brad Roberts
post May 2 2005, 09:53 PM
914 Freak!
I have to agree with Eric, change to larger brakes and change out your fluid and M/C. A fast car is only as good as it's brakes.
A proper stock system with GREAT pads will work just fine.
John,
You nailed it. The next "greatest" thing is the unltra expensive Castrol brake fluid.
There is nothing wrong with the stock brakes. Trekkor fits in the same category as everyone else who has brake issues:
1.shitty fluid
2.shitty pads
3.worn stock components
All this adds up to a person who compounds the issue by hanging on the brake pedal because the car wont stop. Get GREAT pads. Replace the lines. Get a tee. Put a 19mm in.
B
trekkor   Brakes   May 2 2005, 09:26 PM
Brad Roberts   Should I answer.. or do you want me to wait ?   May 2 2005, 09:28 PM
Andyrew   lol You know no one is going to reply now..... l...   May 2 2005, 09:32 PM
nebreitling   probably having 100% FRESH brake fluid in your car...   May 2 2005, 09:32 PM
drew365   I probably should let Brad answer since he knows y...   May 2 2005, 09:34 PM
Eric_Shea     May 2 2005, 09:38 PM
Series9   Aren't 986 Monoblocks getting pretty cheap? G...   May 2 2005, 09:40 PM
Aaron Cox     May 2 2005, 09:42 PM
drew365   ...   May 2 2005, 09:45 PM
SirAndy     May 2 2005, 09:45 PM
skline   I have to agree with Eric, change to larger brakes...   May 2 2005, 09:46 PM
VegasRacer     May 2 2005, 09:48 PM
SirAndy   ...   May 2 2005, 09:53 PM
  May 2 2005, 09:53 PM Brad Roberts   Aaron, Help me out.. <...   May 2 2005, 09:56 PM
SirAndy   i added a green arrow to show you your real proble...   May 2 2005, 09:56 PM
trekkor   John, you answered my question, nicely. Nathan, I...   May 2 2005, 09:58 PM
nebreitling   lmao andy!   May 2 2005, 09:58 PM
Brad Roberts   I cant say antyhingnlkwenqRQGK   May 2 2005, 10:01 PM
Brad Roberts
  May 2 2005, 10:02 PM
Aaron Cox   http://www.914world.com/bbs2/ht...   May 2 2005, 10:15 PM
!   I was running a 2800 lbs tail dragger with stock S...   May 2 2005, 10:24 PM
trekkor
  May 2 2005, 10:47 PM
Andyrew   Soo.... SS lines are better than rubber lines? ...   May 2 2005, 10:48 PM
Brett W   Alright, here goes Leave the air dam on and put s...   May 2 2005, 10:53 PM
neo914-6
  May 2 2005, 11:26 PM
trekkor   Just curious, did Chris' race car run a tee? H...   May 3 2005, 12:01 AM
Eric_Shea   Just Autocross? Stock brakes should be fine. Get...   May 3 2005, 12:06 AM
nebreitling   doesn't seem like anyone here is really fretti...   May 3 2005, 12:14 AM
Eric_Shea   I think you're right but my last post was pret...   May 3 2005, 12:24 AM
Brad Roberts
  May 3 2005, 12:43 AM
ArtechnikA
  May 3 2005, 11:50 AM
Dave_Darling   I would recommend the Porterfield street compound ...   May 3 2005, 12:19 PM
ArtechnikA
  May 3 2005, 12:57 PM
jgiroux67   ...   May 3 2005, 04:32 PM
trekkor   Here's what I'm going to do:   May 4 2005, 06:06 AM
Brett W   http://www.914world.com/bbs2/h...   May 4 2005, 07:02 AM
KenH   ATE Blue fluid or eqiuv. Porterfields are hard to...   May 4 2005, 09:38 AM
- Lo-Fi Version Time is now: 11th July 2025 - 06:53 AM
