Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Sure, this is a re-run.
I ran the track and got brake fade 3/4 of way into each session. I just want to upgrade the pads and fluid right now. What do you recommend/are using. Wear is not a factor. I want the best stopping power for the stock FOUR calipers/rotors. Do I need to replace the M/C with a bigger unit and what are your feelings on the prop valve vs "tee" arguement. Also considering the SS brake lines. Thanks and thanks to Mark for helping with the brake bleeding on track day. KT Attached image(s) ![]() |
jgiroux67 |
Guitar Shredder ![]() ![]() ![]() Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 ![]() |
What about A calipers in front and stock 4's in the rear? I just put in a T but will that be enough to get atleast some power to the rears or should I use realy good pads in the rear and just decent one in the front? |
Lo-Fi Version | Time is now: 11th July 2025 - 07:11 AM |
