Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Sure, this is a re-run.
I ran the track and got brake fade 3/4 of way into each session. I just want to upgrade the pads and fluid right now. What do you recommend/are using. Wear is not a factor. I want the best stopping power for the stock FOUR calipers/rotors. Do I need to replace the M/C with a bigger unit and what are your feelings on the prop valve vs "tee" arguement. Also considering the SS brake lines. Thanks and thanks to Mark for helping with the brake bleeding on track day. KT Attached image(s) ![]() |
KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
ATE Blue fluid or eqiuv.
Porterfields are hard to "bed-in". If they are not bedded-in properly thet may never be right. I use PAGID "Orange". Simple to "bed-in". They work good "cold" or "hot". ie A/X - track. Never a problem braking from 100mph to a sharp 90 turn. Ken 180 |
Lo-Fi Version | Time is now: 11th July 2025 - 08:46 AM |
