cleaning the trans..., anyone know.....? |
xsboost90 |
May 5 2005, 03:15 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
decided to clean my trans last nite and came across some numbers on the bottom, anyone know what they refer to? It also has a "socket" that the ball on the trans pops into on the fork for the throwout bearing, does this need to fit real tight or can it have alittle play, i took it all apart and cleaned it but even when the alan bolt is tight the arm has some play in it.
Im going to clean alittle more and change to mobil 1 90w fluid tonite, almost ready to attach it to the motor!!! Attached image(s) |
JWest |
May 5 2005, 04:34 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
There is a nylon cup (901 116 741 01) that goes into the fork - you probably need to replace it. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:50 AM |
