cleaning the trans..., anyone know.....? |
xsboost90 |
May 5 2005, 03:15 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
decided to clean my trans last nite and came across some numbers on the bottom, anyone know what they refer to? It also has a "socket" that the ball on the trans pops into on the fork for the throwout bearing, does this need to fit real tight or can it have alittle play, i took it all apart and cleaned it but even when the alan bolt is tight the arm has some play in it.
Im going to clean alittle more and change to mobil 1 90w fluid tonite, almost ready to attach it to the motor!!! Attached image(s) |
TimT |
May 5 2005, 06:15 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Mobil 1 isnt the best choice of gear lube for 901s. 901 have balk type synchros, and synthetic gear oils are alklegedly to slippery for them. Although I have used Mobil 1 in 901s in the past. Use some good quality dino oil, unless of course you already bought the
Mobil 1 |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:11 AM |
