Clutch/flywheel Gurus, What does this indicate? |
Joseph Mills |
May 7 2005, 05:53 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
The flywheel pictured below has 5k miles on it along with a new pressure plate, clutch disc, throw out bearing, etc.
Clutch slips under full immediate throttle from a healthy four. What are all the "spots" an indication of? Attached image(s) |
Joseph Mills |
May 8 2005, 06:53 PM
Thanks everyone for each of your suggestions. I made a list and checked each item. The clutch cable is new and has slack in it where it connects to the clutch fork. The pivot fork seems to be properly located with space on either side of it at the bell housing. I remember installing the pivot ball all the way in with no spacers behind it. The pressure plate tangs are even and there are no cracks in the spring pieces and the large rivets are tight. The flywheel is brand new and has not been resurfaced. However, I would like to check the depth of the surface to make sure I was provided the right flywheel. I could not find any info in my Haynes manual. Does anyone know what exactly I need to measure and what the spec should be? |
Lo-Fi Version | Time is now: 13th June 2024 - 10:41 PM |
