Transmission cooler Help..., Not sure where to Tap |
joea9146 |
May 9 2005, 06:24 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I am installing a Tranny cooler... I got the fittings to fit the drain and fill plug .
Everything was going fine until I got under the car. The Throttle linkage for the 6 blocks the drain plug. So I was going to tap the case next to the plug and insert the fitting there. My only apprehension is the case in that area has a slight bevel where I want to tap it... Any ideas or other suggestions. Attached image(s) |
TimT |
May 9 2005, 06:38 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
That is a rather large fitting for transmission cooling.. you may have a problem with tappin into that arear of the transmission.. a gear cluster lives near there..
get a smaller fitting, and tap the case on the other side of the drain |
Lo-Fi Version | Time is now: 4th June 2024 - 01:05 PM |
