Transmission cooler Help..., Not sure where to Tap |
joea9146 |
May 9 2005, 06:24 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I am installing a Tranny cooler... I got the fittings to fit the drain and fill plug .
Everything was going fine until I got under the car. The Throttle linkage for the 6 blocks the drain plug. So I was going to tap the case next to the plug and insert the fitting there. My only apprehension is the case in that area has a slight bevel where I want to tap it... Any ideas or other suggestions. Attached image(s) |
TimT |
May 9 2005, 06:49 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
yes on the other side of the case. the drain on the 914 tranny is passenger side.. take your oil from the drivers side.. if you are in the same plane as the drainplug, you wont have to worry about interference with gears etc..
Lo-Fi Version | Time is now: 29th May 2024 - 02:25 AM |
