Transmission cooler Help..., Not sure where to Tap |
joea9146 |
May 9 2005, 06:24 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I am installing a Tranny cooler... I got the fittings to fit the drain and fill plug .
Everything was going fine until I got under the car. The Throttle linkage for the 6 blocks the drain plug. So I was going to tap the case next to the plug and insert the fitting there. My only apprehension is the case in that area has a slight bevel where I want to tap it... Any ideas or other suggestions. Attached image(s) |
MattR |
May 10 2005, 01:09 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
I read somewhere that the factory used a cooler to spray directly on the gears to keep the gears cool. Maybe I got something mixed up, but wouldnt an arbitrary location kinda defeat the purpose of an oil cooler? I know you're cooling off fluid, but will it really effectivly cool off the gears? And what do you use to pressurize the fluid?
Lo-Fi Version | Time is now: 29th May 2024 - 05:27 AM |
