Transmission cooler Help..., Not sure where to Tap |
joea9146 |
May 9 2005, 06:24 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I am installing a Tranny cooler... I got the fittings to fit the drain and fill plug .
Everything was going fine until I got under the car. The Throttle linkage for the 6 blocks the drain plug. So I was going to tap the case next to the plug and insert the fitting there. My only apprehension is the case in that area has a slight bevel where I want to tap it... Any ideas or other suggestions. Attached image(s) |
Aaron Cox |
May 10 2005, 01:12 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
916 boxes had spraybars and an internal pump IIRC and in Iamchappy's pics, you can see his electrical oil pump. |
Lo-Fi Version | Time is now: 4th June 2024 - 06:30 PM |
