Transmission cooler Help..., Not sure where to Tap |
joea9146 |
May 9 2005, 06:24 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I am installing a Tranny cooler... I got the fittings to fit the drain and fill plug .
Everything was going fine until I got under the car. The Throttle linkage for the 6 blocks the drain plug. So I was going to tap the case next to the plug and insert the fitting there. My only apprehension is the case in that area has a slight bevel where I want to tap it... Any ideas or other suggestions. Attached image(s) |
slivel |
May 10 2005, 01:16 PM
Old car....... older driver Group: Members Posts: 510 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Yes, a spray bar is most effective but understand that the pictures displayed only show the output side of the loop. From the drain plug area the hot oil goes to a pump and cooler then returns to the gearbox. The return can be plumbed to a spray bar over the gearset. In my case, I drilled and tapped one hole over the ring and pinion to dump the cooled oil. Next time I have the gear box apart I might tap 2 or 3 more holes over the gearset for additional cooling. |
Lo-Fi Version | Time is now: 4th June 2024 - 01:19 PM |
