Clutch/flywheel Gurus, What does this indicate? |
Joseph Mills |
May 7 2005, 05:53 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
The flywheel pictured below has 5k miles on it along with a new pressure plate, clutch disc, throw out bearing, etc.
Clutch slips under full immediate throttle from a healthy four. What are all the "spots" an indication of? Attached image(s) |
Cap'n Krusty |
May 11 2005, 01:22 PM
Bus PPs look a lot different than the Porsche ones. The diaphragm is of a different design, and the release bearing is far different. The Porsche bearing doesn't mate up to the PP, and the VW bearing won't work on the 914 tranny. As I recall, the flywheel is cut differently, and the step height may be different. I know GPR sells the VW disc as a "low cost alternative", and I've used one in a "just make it run so I can sell it" situation. The savings isn't worth it, IMO. The Cap'n |
Lo-Fi Version | Time is now: 1st June 2024 - 02:46 AM |
