Got my Sunpro Digital Engine Analyzer CP7676, Sooo easy! Must Have! |
yarin |
May 25 2005, 08:03 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
'72 914-4 Webers 40s, stock motor
I got my meter off ebay for $24, hooked it up right away and BAM. My dwell was set to 46 degrees after gaping it with a feeler gauge. So I nudged it a bit and BAM... 49 degrees. pretty damn good. RPM works like a charm as well. I'm thinking about setting up a temporary mount inside the car hardwired for voltage, rpm and dwell. I'm taking this piece of crap Craftsman Engine Analyzer back to Sears, what a waste of 50 bucks for an analog meter. Then I busted out the timing light with advance, held at 3k rpm and adjusted the distributor to line up with TDC. I briefly caught another mark, but the mark that i lined up with is immediately to the right of the large fin on the fan. Is this correct? I'll take it for a spin tommorow and see how it runs. Sounds much better than before though. After that i will adjust the valves, one of the cylinders keeps backfiring through the intake. Hopefully its a valve clearance issue. If i'm still having problems then i'm going to order a set of those carb flow meters and learn to tune carbs. This is all on my crappy engine. I want to get some experience on these Type IVs before i drop in my higher power motor. Is my sequence of tuning correct? 1) Dwell 2) Timing Advance 3) Valves 4) Carbs |
TimT |
May 25 2005, 08:26 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
valves first
Lo-Fi Version | Time is now: 11th June 2024 - 11:03 PM |
