> Tips to reinstall master cylinder?, Plastic lines - come out or kink!!
william harris
post Jun 18 2005, 09:43 AM
914 Restorer
OK, exhausted myself (of course working under jack stands is never fun) last night trying to reinstall the master cylinder so I could hook up Eric Shea's beautiful (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) pedal assembly (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) As anyone who has done this knows, the plastic lines up to the reservoir connect to about a three inch long brass line that fits into two press fit rubber boots on top of the master cylinder. Well you can't press them in after the cylinder is attached to the bolts coming thru from the pedal assembly. So what I have tried and tried to do is to pull the lines down about an inch or so, push them in and then have my son gently pull the lines up from the top while I push the master cylinder onto the bolts and into position. It just ain't working. Either the plastic lines kink (not good) or the damn things pull out of the master cylinder before I can get it into place. After trying this approach for about an hour I decided it was time to go watch TV. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) Any suggestions for a better method? Oh, the damn grommets want to come out of the lower panel when you push the lines, making for more mischief. I gotta remind myself I do this for fun and enjoyment. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
mihai914
post Jun 18 2005, 11:06 AM
The only way I managed to do this is with the master bolted up and the lines loose. I know it's a big bitch to put those grommets in. This was my trick that took me an hour to figure out. You can't pry those in very easily but if you use a fuel injection hose clip it makes life much easier.
Put some soap or lubricant on the grommet and then put the clip around it and start squeezing it. The damn thing may slip so you have to compress the grommet perfectly, once it squeezed enough center it over the master hole and press in fast, it should slip out of the clip and in the master.
It may take you a couple of tries but this was by far the best way I managed to get those lines in.
william harris   Tips to reinstall master cylinder?   Jun 18 2005, 09:43 AM
Mueller   are the hoses still connected to the fluid resevo...   Jun 18 2005, 10:14 AM
william harris   No,they are loose. Hell, there ain't no reser...   Jun 18 2005, 10:18 AM
mihai914   The only way I managed to do this is with the mast...   Jun 18 2005, 11:06 AM
Grimstead   This is just a guess as I haven't put mine bac...   Jun 18 2005, 11:15 AM
mihai914   It's almost impossible because of the twist th...   Jun 18 2005, 11:19 AM
mikelsr   If I can remember correctly here is what I did (af...   Jun 18 2005, 11:20 AM
Travis Neff     Jun 18 2005, 12:06 PM
william harris   OK, I was afraid this might be part of the problem...   Jun 18 2005, 03:37 PM
Gint   Screw in the reservoir and then just put the lines...   Jun 18 2005, 05:22 PM
william harris   OK, looks like my father's day project.   Jun 18 2005, 06:53 PM
watsonrx13   William, I just installed my new MC and lines last...   Jun 18 2005, 07:10 PM
watsonrx13   Here's a shot underneath the fuel tank (remove...   Jun 18 2005, 07:11 PM
watsonrx13   Eric, here's the shot of my pedal cluster inst...   Jun 18 2005, 07:12 PM
firstknight13   http://www.914world.com/bbs2/...   Jun 18 2005, 08:43 PM
william harris   Thanks for all the help guys. Let's see how w...   Jun 18 2005, 09:13 PM
Eric_Shea
  Jun 18 2005, 10:38 PM
Doug Leggins   Eric, I installed mine yesterday. VERY nice produ...   Jun 18 2005, 11:59 PM
Doug Leggins   William - THANKS for posting this topic. I install...   Jun 19 2005, 12:17 AM
Doug Leggins   another   Jun 19 2005, 12:19 AM
Doug Leggins   top side   Jun 19 2005, 12:19 AM
jgiroux67   I did this no problem. The MC was bolted in too. ...   Jun 19 2005, 12:25 AM
Doug Leggins   I just compared the routing of the brake lines in ...   Jun 19 2005, 12:32 AM
Gint   Good question... Here's a
  Jun 19 2005, 10:50 PM
- Lo-Fi Version Time is now: 15th July 2025 - 01:12 AM
