> Brake bleeding made simple..., Never a bummer again!
Trekkor
post Jun 24 2005, 02:54 PM
I do things...
Here it is, the moment you've been waiting for.
You'll spend more time taking the wheels off and on, if you do this!
Install Speedbleeders.
Put 10' long clear vinyl tube over the bottom bleeder on the right rear.
Drape hose into brake reservoir after flushing system and secure with a zip tie.
Crack Speedbleeder 1/4 turn and pump until you see the bubles stop going by.
Tighten speed bleeder and move to upper bleeder.
Fold hose over on itself and secure with a clamp between calipers to keep the prime in the hose and avoid making a mess.
Repeat for left rear, right front and left front.
This is *TOO* easy.
KT
McMark
post Jun 24 2005, 03:57 PM
914 Freak!
BLEED ALL NIPPLES. As Trekkor said, skipping some saves you 5 minutes and could leave you with mushy brakes. I used to skip them and it never worked. Now I'll never skip one again.
trekkor   Brake bleeding made simple...   Jun 24 2005, 02:54 PM
Aaron Cox   ummm... why are you using the BOTTOM bleeder... a...   Jun 24 2005, 02:56 PM
Part Pricer   http://www.914world.com/bbs2/h...   Jun 24 2005, 02:59 PM
trekkor   After the fluid starts going into the reservoir, s...   Jun 24 2005, 03:01 PM
trekkor   The long hose will reach all valves and pass by th...   Jun 24 2005, 03:08 PM
trekkor   Clamp it! When you are all done, just throw ...   Jun 24 2005, 03:12 PM
Dr Evil   I wondered if that would work, but was always in t...   Jun 24 2005, 03:14 PM
Part Pricer   This thread should be in the Classic section.   Jun 24 2005, 03:17 PM
nocones   This is how I bleed my motorcycle brakes when I...   Jun 24 2005, 03:27 PM
McMark   BLEED ALL NIPPLES. As Trekkor said, skipping some...   Jun 24 2005, 03:57 PM
trekkor   All done. Easy. Perfect. The first time. If you b...   Jun 24 2005, 08:09 PM
Travis Neff   Nice writeup and process there Trekkor. Next time...   Jun 24 2005, 08:13 PM
TimT   Trekkors method is a good one, as a nother example...   Jun 24 2005, 08:15 PM
!     Jun 24 2005, 08:36 PM
qa1142   You really don't want to do it this way 1) moi...   Jun 25 2005, 08:07 AM
jim912928   I'm also not sure you want to do this. Alot o...   Jun 25 2005, 08:14 AM
!     Jun 25 2005, 08:16 AM
trekkor
  Jun 25 2005, 09:01 AM
!   <...   Jun 25 2005, 09:31 AM
trekkor   I have seen the fluid...Read "my fluid" at Streets...   Jun 25 2005, 09:51 AM
Air_Cooled_Nut
- Lo-Fi Version Time is now: 2nd April 2026 - 03:06 PM
