| skline |
Aug 3 2005, 06:04 PM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Car runs great, I think it is running a tad on the warm side. Also, when it is running warmer than normal around 210 consistently, I notice the Voltmeter goes to max. If I shut it off, it goes back to normal and when I restart the car it stays at around 14 volts but when I rev the motor it runs back up to max again. Any ideas on what would cause that? It just started doing it when the car started running warmer than it was, it used to run at 180 to 190 but now it's up to 210. Anyone know what is going on?
| 914GT |
Aug 3 2005, 08:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Scott
If I recall correctly you recently replaced your alternator. How did you wire it up? If something is hosed with the wiring, or if the alternator has a defective regulator or field circuit, the voltage can go too high. Put a DVM on the battery and see what it's running since it's pegging the console gauge. Too high or too low voltage can definitely cause errors in your temp gauge. |
skline Got a question for V8 Gurus Aug 3 2005, 06:04 PM
John2kx Scott,
Since your car was running consistant at 1... Aug 3 2005, 06:22 PM
skline John, that thought did cross my mind, they are ele... Aug 3 2005, 07:11 PM
skline Matt and I just hooked up the VOM to the battery a... Aug 3 2005, 09:08 PM
bondo I hope you aren't running an optima, they don... Aug 3 2005, 09:20 PM
John2kx Aug 4 2005, 07:36 AM
James Adams Aug 4 2005, 08:25 AM
Twystd1 Scott,
If I am not mistaken, I believe Slits told ... Aug 4 2005, 08:30 AM
skline I got a reply this morning from the guy I got the ... Aug 4 2005, 08:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th July 2026 - 03:42 AM |
