> OT: Backyard pond with Aquarium type "window"?
Mueller
post Aug 9 2005, 08:11 PM
914 Freak!
Okay, I built an in-ground pond a few years ago...guess it's a few hundred gallons...it is surrounded by 2500 pounds of flagstone....after killing all 40+ goldfish last year*, I've let the pond dry up and now it's a trip hazard (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Now I'd like to rebuild it with a new and better pump and filter. But instead of keeping it in-gound, I'd like to raise it up and make a viewing window at least a foot or so from the ground level..basicly a one-window aquarium.
Anyone have experiance with making something similar?
Should I plexiglass or tempered glass? What about sealing it to the rest of the pond walls?
*too much tap water into it when I drained it to clean it out some....poor fish (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
john rogers
post Aug 9 2005, 08:19 PM
I had a cousin back on the east coast (deceased now) who built several aquarium "walls" and used 1 inch thick tempered glass since they went to the ceiling. Remember the force of wather is about 1/2 pound per square inch per foot of height so the glass has to be pretty strong. If you are going up a foot or so then 3/8 inch should work okay. To seal it, I'd lay out the surfaces it sits against, seal them with a thin layer of concrete and then use GOOP sealer to glue the glass to it. If it were on a hill such as my back yard then the window could be much higher. This is on my todo list some day when I retire......
Mueller   OT: Backyard pond with Aquarium type "window"?   Aug 9 2005, 08:11 PM
jkeyzer   So I'm not an expert on aquariums or anything ...   Aug 9 2005, 08:13 PM
redshift   Google.. If you need new koi, I can work somethin...   Aug 9 2005, 08:16 PM
john rogers   I had a cousin back on the east coast (deceased no...   Aug 9 2005, 08:19 PM
Mueller   <...   Aug 9 2005, 08:19 PM
Jeff Bowlsby   I think you should use 914 glass pieces Mike....ma...   Aug 9 2005, 08:22 PM
snflupigus   I'd use plexi... probably a TON cheaper but it...   Aug 9 2005, 08:41 PM
jgara962   I built a 1,400 gallon koi pond with a stream and ...   Aug 9 2005, 09:40 PM
Britain Smith   I wanna see a picture of your pond...post it here...   Aug 9 2005, 09:55 PM
MW 914     Aug 9 2005, 10:06 PM
jgara962   Hopefully this works...   Aug 9 2005, 11:02 PM
trekkor   Nice pond. I've always liked ponds...Used to ...   Aug 9 2005, 11:51 PM
Travis Neff   Stop peeing in the pond and the fishies might stic...   Aug 10 2005, 12:05 AM
airsix   Mike, Too much work. Just get one of these instead...   Aug 10 2005, 12:49 AM
Mikey914   I do not have experience building ponds but use 1/...   Aug 10 2005, 01:42 AM
jgara962     Aug 10 2005, 09:49 AM
Brian Mifsud   Mike, Sunlight will degrade plastic over time. I...   Aug 10 2005, 10:41 AM
MikeP   Yep go glass. You can get these very cool magneti...   Aug 10 2005, 12:17 PM
markb   Fill it back up with water & put new fish in it. S...   Aug 10 2005, 01:47 PM
- Lo-Fi Version Time is now: 12th July 2025 - 10:57 AM
