Need help with minor electrical problem, Radio and wipers |
MoveQik |
Sep 12 2005, 12:00 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I was screwing around with the wiring on my radio yesterday and heard a snap crackle pop. Now my radio and my wipers don't work. Not sure why. I didn't think they were hooked up on the same fuse. Besides that, I have checked all fuses and everything appears to be good. I checked the fuse panel, none are blown. I replaced one fuse on the stereo as is blew but the other one was fine.
Everything worked before I attempted to "clean up the wiring." Now the wipers and rado are MIA. Any suggestions? Below shows where I hooked the radio into the fuse panel. Any advice is appreciated! Attached image(s) |
MoveQik |
Sep 13 2005, 02:07 PM
Ok....I went out with a test light and this is what I found....for all I know this is the way it should be. The 3 on the right had power on both sides of the fus at all times. The 4th from the right only had power when the ignition is on. All the others had nothing at all times. Does that help you guys trouble shoot my problem? If not, give me some more advice and send me back out there!
Attached image(s) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:54 AM |
