| Hawktel |
Sep 17 2005, 10:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 2-April 03 From: Ogden Utah Member No.: 506 |
So the new Impalla that chevy has released has a option for a 330 HP V8 with 28 highway fuel consumption.
Thats amazing. Just amazing. I wonder how far fuel efficency can be pushed? |
| jniemeier |
Sep 20 2005, 04:08 PM
Newbie ![]() Group: Members Posts: 18 Joined: 7-December 03 From: Western New York Member No.: 1,424 |
This followup will be short, I promise.
Reduction in "pumping losses" is why Deac improves economy. By pumping losses I mean the work required to pull down on intake against the restriction of the throttle blade. When in 4 cyl mode, a deac engine has it's throttle blade further open than it would in 8 cyl mode at the same speed-load point. Think: working harder on the remaining four cylinders. Further open means air flows in easier, i.e. less losses. If you mean the frictional losses of the piston going up and down with both valves closed all the time, yes of course that is an unavoidable loss of efficiency, but it's not that bad, cuz the work required to compress the air is recovered when it expands. You only lose the friction, which isn't terrible with a warm engine and the low tension rings they use now-a-days. Saab's Variable Compression engine is no doubt still around, and still in development. (Did you hear about the one that sparked from the plug to the top of the piston? Those Swedes!) These things take years. I've also seen one from FEV, a Euro engine design company in their Detroit office. It's a steep uphill challenge: added complexity means lower reliability, and more variables means tougher to meet emissions reg's, which is the hardest aspect of designing an engine. And when a new engine line costs many hundreds of millions, they tend to be a conservative bunch. Believe me. Very conservative. On the other hand, engines are now extremely reliable when you think about it. OK, not short, but let's call this one medium. See you around. Good questions. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) Jim N '73 2.0 |
Hawktel Amazing Sep 17 2005, 10:56 PM
Elliot Cannon 28 miles per gallon at what speed? 55? 60?
... Sep 17 2005, 11:07 PM
Hammy Had to be a typo http://www.914wo... Sep 17 2005, 11:07 PM
Hammy From Chevy site
