> Amazing, Chevy builds a 330 HP engine with 28mpg
Hawktel
post Sep 17 2005, 10:56 PM
So the new Impalla that chevy has released has a option for a 330 HP V8 with 28 highway fuel consumption.
Thats amazing. Just amazing. I wonder how far fuel efficency can be pushed?
phantom914
post Sep 21 2005, 11:12 PM
non-914-owner non-club member
Jim,
Makes sense. If an engine had individual drive-by-wire throttles, would it be simpler to switch those out (closed) rather than the valves? And what if there were similar butterfly or other type of valves on the exhaust side. Wouldn't it be less complex than deactivating the valvetrain? Or if not less complex, would it work? I think it wouldn't work as well since the butterfly valves woudn't seal as well as a closed cylinder-head valve. I am just curious whether you think it would work at all since that would seem to address the pumping loss issues you mention. Don't think that I was thinking of trying it.....(IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) .....this year... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) ... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I do still think (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) that (maybe?) a fuller cylinder will burn more efficiently. It is harder to ignite and sustain ignition in a partially filled cylinder compared to a more fully filled one. I don't know the exact mechanism(s), but the pressure developed before and after ignition, heat generated by combustion and heat rate lost to cylinder walls etc affect ease of starting/sustaining combustion and also energy output/efficiency. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Some of these factors would be affected by the amount of cylinder filling, wouldn't they?
Also, a car will get better mileage with higher gearing. Which of these factors are significant: 1) less frictional loss due to engine turning fewer revs over a given distance2) less pumping loss due to higher throttle opening 3) increased efficiency due to greater cylinder filling 4) any thing I didn't mention.
Is that too many questions? (oops, that was another one)
Andrew
Hawktel   Amazing   Sep 17 2005, 10:56 PM
Elliot Cannon   28 miles per gallon at what speed? 55? 60? ...   Sep 17 2005, 11:07 PM
Hammy   Had to be a typo http://www.914wo...   Sep 17 2005, 11:07 PM
Hammy   From Chevy site   Sep 17 2005, 11:14 PM
Twystd1   My bro has a 2003 Vette with the z06 package and a...   Sep 17 2005, 11:23 PM
DonTraver   Cadilac's (sp)   Sep 17 2005, 11:24 PM
Travis Neff   Ayup, my Dad has a the last year WS6 Trans Am with...   Sep 17 2005, 11:25 PM
redshift   Simple: The stated EPA milage is an F'ING LIE....   Sep 18 2005, 12:20 AM
sean_v8_914   I just drove a new Vette on a mini AX style track ...   Sep 18 2005, 02:10 AM
Hammy   How does the vette handle?   Sep 18 2005, 02:18 AM
TimT   Im sure the vette handles pretty well.. the assho...   Sep 18 2005, 05:42 AM
Gint     Sep 18 2005, 07:12 AM
Dr Evil   I believe it is called "variable displacement." My...   Sep 18 2005, 07:50 AM
seanery   Chrysler has been doing the multiple displacement ...   Sep 18 2005, 08:16 AM
Pugbug   They are all liars!...This from Consumers Repo...   Sep 18 2005, 12:14 PM
redshift   Stop-and-Go numbers in my city, are higher than 90...   Sep 18 2005, 12:24 PM
Headrage     Sep 18 2005, 12:31 PM
bd1308   how does the system work? are the fuel injectors s...   Sep 18 2005, 12:31 PM
bd1308   ...   Sep 18 2005, 12:32 PM
snflupigus   Imagine, displacement on demand, variable compress...   Sep 18 2005, 12:41 PM
snflupigus     Sep 18 2005, 12:50 PM
anthony   How is it that manufacturers cheat by such a large...   Sep 18 2005, 12:55 PM
Pugbug   And the fuel economy winner is........The Pac car ...   Sep 18 2005, 02:30 PM
snflupigus   i used to get about 25mpg average on interstate tr...   Sep 18 2005, 03:31 PM
bd1308   on your 914 comment, I couldn't agree more. T...   Sep 18 2005, 05:17 PM
dmenche914   The 914 is light enough, so it does not need a ton...   Sep 18 2005, 05:22 PM
groot   The manufacturers don't cheat on the sticker n...   Sep 19 2005, 05:46 AM
roundboy914   not for nothing, but i think the HP rating was 303...   Sep 19 2005, 07:56 AM
andys   Though I've only put four tankfulls' since...   Sep 19 2005, 09:50 AM
snflupigus   at least comparitively they are useful... one truc...   Sep 19 2005, 10:10 AM
jniemeier   I'm new to the group, but you're on a topi...   Sep 19 2005, 01:04 PM
jd74914   very interesting. thanks   Sep 19 2005, 01:30 PM
groot   Great post, Jim!!! I hadn't read ...   Sep 19 2005, 01:46 PM
914efi   What happened to Saab's variable compression e...   Sep 19 2005, 01:58 PM
BIGKAT_83   Great post Jim.............. Thanks for the info ...   Sep 19 2005, 02:09 PM
Rotary'14   IIRC the EPA accepts data provided from the manufa...   Sep 19 2005, 04:04 PM
jniemeier   This followup will be short, I promise. Reduction ...   Sep 20 2005, 04:08 PM
Mueller   thanks Jim http://www.914wor...   Sep 20 2005, 04:20 PM
phantom914   Jim N, I have a dumb question which I ask because...   Sep 20 2005, 04:35 PM
ewdysar   As long as we're on a rant topic... OK we...   Sep 21 2005, 03:41 PM
jniemeier   First, Eric- I agree completely. We could cut the...   Sep 21 2005, 06:51 PM
jniemeier   We call them ETC's: Electronic Throttle Contro...   Sep 23 2005, 07:49 PM
stock93   Jim N, Check out BMW's N73 6.0L V 12. They are...   Sep 24 2005, 08:32 AM
jniemeier   Yes, it's an amazing engine. Not the first th...   Sep 24 2005, 09:03 AM
snflupigus   Thinking of the whole torque = good for economy wi...   Sep 24 2005, 01:44 PM
Carl   Very interesting information, Jim. For a long tim...   Sep 25 2005, 01:20 AM
snflupigus   The selenoids would also have to operate at certai...   Sep 25 2005, 02:48 AM
J P Stein     Sep 26 2005, 11:15 PM
Dr. Roger
  Sep 27 2005, 08:16 PM
Dr. Roger   <...   Sep 27 2005, 09:09 PM
messix   the push rod would have as much force as it would...   Sep 27 2005, 09:18 PM
phantom914
- Lo-Fi Version Time is now: 2nd April 2026 - 09:17 PM
