> Amazing, Chevy builds a 330 HP engine with 28mpg
Hawktel
post Sep 17 2005, 10:56 PM
So the new Impalla that chevy has released has a option for a 330 HP V8 with 28 highway fuel consumption.
Thats amazing. Just amazing. I wonder how far fuel efficency can be pushed?
jniemeier
post Sep 23 2005, 07:49 PM
We call them ETC's: Electronic Throttle Control, and no, that won't work. For one, you can't put an ETC into a 500deg C exhaust stream. Well, you could, but it wouldn't live long. Why do you think this would work better? Doing it in the valvetrain is the closest to the combustion chamber we're trying to control and by far the most mechanically simple (engineers would say, "elegant") solution. There's no need to think up anything else.
Individual throttles implies you're using individual intake runners. Very expensive and won't fit for a V type engine. V engines like plenum's and a single throttle cuz it helps even out the flow balance to the cylinders, fits better, and of course is lots cheaper. Racing engines may have seperate runners, but keep in mind they are optimized around a very narrow rpm band.
Cylinder filling: I don't think you caught what I wrote before. You need to seperate the idea of quality of combustion from the amount of mixture in there. To have acceptable emissions, you need to keep the mixture at 14.7 to 1 air/fuel ratio. Period. After that, the AMOUNT of 14.7:1 mixture we get in there is the thing that directly controls the torque that cylinder makes. At Wide Open Throttle (WOT), less restriction to air flowing in, more mixture in the cylinder, max torque. At idle, tons of restriction past the throttle, little mixture inside, low torque. In both cases, the mixture is always 14.7 to 1. It takes a while to digest that fact. So, things like the ease of initiating the burn, and the combustion 'efficiency' are the same in both cases. The power generated is drastically different of course, so the heat loss to the wall is different, sure, but the efficiency is the same. Engines are most efficient at WOT not because they burn better, but because they don't waste work pulling air past the nearly closed throttle at low loads.
Answer to paragraph #3: Number 1 and 2 are both good, although I think number 1 is the easiest and likely the larger improvement, at least for big V8's. With a 914 engine pushing the car at 70 mph, you can't be lowering the revs too much can you? But, when Chevy was trying to avoid the gas guzzler tax on the Vette inspite of increasing hp to 400 (and now 500!), they went to gearing that left it turning what, 1600 at 70? Something like that. IF you have the torque, that's the easiest way to go. By now, I hope you agree that Number 3, increased filling, is simply a method to increase torque, not improve efficiency, BUT, you can use your increased torque to drive taller gearing, and THAT is option Number 1, the best option. So, 3 is just an enabler for 1. Got it?
Now, since you're such an inquisitive guy, here's my advice I hope you take on board: Go to a used book store (or probably Amazon) and buy a copy of "Internal Combustion Engines and Air Pollution" by Obert. That's the one used in most engineering schools and is the all time classic. Every engine designer in the country has a copy in his office. Read the whole thing. It's actually not that hard to read. I'm sure you will get a ton out of it.
(IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) Jim N.
Hawktel   Amazing   Sep 17 2005, 10:56 PM
Elliot Cannon   28 miles per gallon at what speed? 55? 60? ...   Sep 17 2005, 11:07 PM
Hammy   Had to be a typo http://www.914wo...   Sep 17 2005, 11:07 PM
Hammy   From Chevy site   Sep 17 2005, 11:14 PM
Twystd1   My bro has a 2003 Vette with the z06 package and a...   Sep 17 2005, 11:23 PM
DonTraver   Cadilac's (sp)   Sep 17 2005, 11:24 PM
Travis Neff   Ayup, my Dad has a the last year WS6 Trans Am with...   Sep 17 2005, 11:25 PM
redshift   Simple: The stated EPA milage is an F'ING LIE....   Sep 18 2005, 12:20 AM
sean_v8_914   I just drove a new Vette on a mini AX style track ...   Sep 18 2005, 02:10 AM
Hammy   How does the vette handle?   Sep 18 2005, 02:18 AM
TimT   Im sure the vette handles pretty well.. the assho...   Sep 18 2005, 05:42 AM
Gint     Sep 18 2005, 07:12 AM
Dr Evil   I believe it is called "variable displacement." My...   Sep 18 2005, 07:50 AM
seanery   Chrysler has been doing the multiple displacement ...   Sep 18 2005, 08:16 AM
Pugbug   They are all liars!...This from Consumers Repo...   Sep 18 2005, 12:14 PM
redshift   Stop-and-Go numbers in my city, are higher than 90...   Sep 18 2005, 12:24 PM
Headrage     Sep 18 2005, 12:31 PM
bd1308   how does the system work? are the fuel injectors s...   Sep 18 2005, 12:31 PM
bd1308   ...   Sep 18 2005, 12:32 PM
snflupigus   Imagine, displacement on demand, variable compress...   Sep 18 2005, 12:41 PM
snflupigus     Sep 18 2005, 12:50 PM
anthony   How is it that manufacturers cheat by such a large...   Sep 18 2005, 12:55 PM
Pugbug   And the fuel economy winner is........The Pac car ...   Sep 18 2005, 02:30 PM
snflupigus   i used to get about 25mpg average on interstate tr...   Sep 18 2005, 03:31 PM
bd1308   on your 914 comment, I couldn't agree more. T...   Sep 18 2005, 05:17 PM
dmenche914   The 914 is light enough, so it does not need a ton...   Sep 18 2005, 05:22 PM
groot   The manufacturers don't cheat on the sticker n...   Sep 19 2005, 05:46 AM
roundboy914   not for nothing, but i think the HP rating was 303...   Sep 19 2005, 07:56 AM
andys   Though I've only put four tankfulls' since...   Sep 19 2005, 09:50 AM
snflupigus   at least comparitively they are useful... one truc...   Sep 19 2005, 10:10 AM
jniemeier   I'm new to the group, but you're on a topi...   Sep 19 2005, 01:04 PM
jd74914   very interesting. thanks   Sep 19 2005, 01:30 PM
groot   Great post, Jim!!! I hadn't read ...   Sep 19 2005, 01:46 PM
914efi   What happened to Saab's variable compression e...   Sep 19 2005, 01:58 PM
BIGKAT_83   Great post Jim.............. Thanks for the info ...   Sep 19 2005, 02:09 PM
Rotary'14   IIRC the EPA accepts data provided from the manufa...   Sep 19 2005, 04:04 PM
jniemeier   This followup will be short, I promise. Reduction ...   Sep 20 2005, 04:08 PM
Mueller   thanks Jim http://www.914wor...   Sep 20 2005, 04:20 PM
phantom914   Jim N, I have a dumb question which I ask because...   Sep 20 2005, 04:35 PM
ewdysar   As long as we're on a rant topic... OK we...   Sep 21 2005, 03:41 PM
jniemeier   First, Eric- I agree completely. We could cut the...   Sep 21 2005, 06:51 PM
phantom914   Jim, Makes sense. If an engine had individual dri...   Sep 21 2005, 11:12 PM
stock93   Jim N, Check out BMW's N73 6.0L V 12. They are...   Sep 24 2005, 08:32 AM
jniemeier   Yes, it's an amazing engine. Not the first th...   Sep 24 2005, 09:03 AM
snflupigus   Thinking of the whole torque = good for economy wi...   Sep 24 2005, 01:44 PM
Carl   Very interesting information, Jim. For a long tim...   Sep 25 2005, 01:20 AM
snflupigus   The selenoids would also have to operate at certai...   Sep 25 2005, 02:48 AM
J P Stein     Sep 26 2005, 11:15 PM
Dr. Roger
  Sep 27 2005, 08:16 PM
Dr. Roger   <...   Sep 27 2005, 09:09 PM
messix   the push rod would have as much force as it would...   Sep 27 2005, 09:18 PM
phantom914
- Lo-Fi Version Time is now: 2nd April 2026 - 07:44 PM
