| shaggy |
Oct 28 2005, 11:47 PM
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
so i decided to change my oil. the car was running fine, very strong, before i attempted anything i got an oil filter cap wrench and a strap wrench to get it out. i got the old filter out and replaced it with a bosch 3402 i tightened it well, maybe too well. filled it with oil to max line, no more. then i started it and i found my oil light to be on so i shut it down. i checked my oil and it was reading empty. what the hell? i just filled it! so i look under the car... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) ...and find that the car had puked all of the oil out from somwhere around the oil filter. so i take the filter out and put a new one in and fill it again. i didnt start it right away i changed my brake pads and went and got more brake fluid and fast orange(that stuff is the work of god) so then i started it again and it puked all the oil out again (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) oil came out from the same general area. all of it... again it was a bosch 3402 so what is going on? did i break anything? is the bosch 3402 the correct oil filter? did i break or lose a seal? how can i fix my car so that it will run, for the first time in about a week? please please if anyone has any information please help. id like to have it running for tomorrow night so i can go on a date with my girlfriend in the 72 914 as opposed to the lincon continental(the boat that dosent handle at all) anyone have any ideas? |
| Aaron Cox |
Oct 30 2005, 05:28 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
cross threaded? (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
this is why you dont use a wrench to put an oil filter on. hand tight, and MAYBE snug it up with a wrench if so inclined. the part bolts on to the case. find someone with an oil filter housing and get a new gasket. and go on with life, and chuck the oilfilter wrench (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) no harm no foul, figure youll be in it 20 bucks + another 4 quarts of oil. CHEAP LESSON (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
shaggy please, please help! Oct 28 2005, 11:47 PM
McMark The oil filter mount is attached to the case by tw... Oct 29 2005, 12:05 AM
jkeyzer I just looked at Kragen's website and it is su... Oct 29 2005, 12:08 AM
shaggy i do have the old filter but i dont know if i wann... Oct 29 2005, 12:17 AM
McMark I'm starting to think you have the wrong filte... Oct 29 2005, 12:17 AM
shaggy setting my alarm now to get up and head to as many... Oct 29 2005, 12:21 AM
Twystd1 Shaggy,
Check to see if the old oil filter still h... Oct 29 2005, 03:47 AM
Jacques Always go with the Mahle!!
http://forum... Oct 29 2005, 03:56 AM
Bleyseng <... Oct 29 2005, 08:57 AM
shaggy i have checked the o ring many times on all of the... Oct 29 2005, 10:29 AM
smg914 Stay away from Fram, Purolator and Bosch filters f... Oct 29 2005, 10:47 AM
shaggy do you guys think that could be my entire problem?... Oct 29 2005, 10:50 AM
bondo Maybe by coincidence, you happend to blow out an o... Oct 29 2005, 10:51 AM
shaggy what is an oil galley plug and how hard is that to... Oct 29 2005, 10:53 AM
brp914 one time I changed the oil and the engine chose th... Oct 29 2005, 11:05 AM
Flat VW It's cross-threaded, http://www... Oct 30 2005, 05:18 PM
Flat VW I am hearing from Shaggy (my son) Oct 30 2005, 06:24 PM
grasshopper hey john, i have an oil filter housing. If you wan... Oct 30 2005, 06:33 PM
shaggy how can i get my oil filter assembly off?
i have ... Oct 30 2005, 07:54 PM
McMark I just checked my "spare" motors and there is abso... Oct 31 2005, 12:18 AM
Flat VW Oct 31 2005, 08:38 AM
Cap'n Krusty Yet ANOTHER instance of WAGuessing and speculation... Oct 31 2005, 09:39 AM
Aaron Cox its a pretty vital part...... just get a spare fro... Oct 31 2005, 09:40 AM
scruz914 Oct 31 2005, 12:16 PM
Flat VW Oct 31 2005, 12:48 PM
Brando Hows the engine dropping going? Pictures? Updates?... Oct 31 2005, 01:59 PM
Flat VW Oct 31 2005, 02:02 PM
Brando Well, what are you doing home at this time... don... Oct 31 2005, 02:04 PM
Flat VW Oct 31 2005, 02:58 PM
Brando Heheh, same here. I should be at the p-car shop to... Oct 31 2005, 03:05 PM
SLITS Oct 31 2005, 03:56 PM
Flat VW Oct 31 2005, 06:27 PM
meares what's wrong with using FRAM filters? Nov 1 2005, 08:02 AM
Dave_Darling Nov 1 2005, 12:29 PM
Brando Nov 1 2005, 01:39 PM
Flat VW Nov 1 2005, 01:42 PM
SLITS Exactly what I would expect from the cover boy for... Nov 1 2005, 03:08 PM
SLITS OH BTW John.....two not one, that's right, two... Nov 1 2005, 03:10 PM
Flat VW Nov 1 2005, 04:30 PM
pfierb Nov 1 2005, 08:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 07:09 PM |
