Engine Build Question and Report, SS struck again |
azbill |
Nov 4 2005, 06:27 PM
Member Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
As an insurance policy, I am having the engine that I bought from (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) Steve Stromburg completely disassembled.
We have found some issues. Excess side play on one of the connecting rods, some of the case bolts missing, over tightened, and some not tightened at all. I don’t think the rods were refurbished. We will be taking them out and throughly go over them. White lithium grease is everywhere. The oil pump was had a fiber gasket and an o-ring seal and the screen was not installed. The heads look good we will be flow testing and cmpletely look them over in detail. There are stainless steel valves - 48mm exhaust with 44 or 45mm intake with heavy duty springs (double springs) and the lifters are ceramic. He used standard adjustment screws. I am wondering if the adjustment screws should be replaced with 911 swivel screw? What are your suggestions? Thank God I took the extra step to open this engine up. It would have been a bigger mess if I had just run it as a “turn key”. To say the least this was one sloppy engine build. Thanks Azbill |
Aaron Cox |
Nov 4 2005, 06:59 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
here is the easiest way to upload multiple pics in a POST
shrink em all to 640x480 or 800x600, and upload them all to your blog. then use
do it for every pic. works great. called Hot-linking from your blog (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:20 AM |
